959 wiring diagrams
Hi , I know this is not the right forum but their isnt one for the 959,
The problem is that the air conditioning compressor clutch does not cut in , Their is sufficient gas in the system and when the clutch is excited via a 12volt direct feed the system does operate. Their is no live feed at the wiring plug above the engine cooling fan, has any body got a diagram or an idea ,All fuses have been checked and are ok ,the geman fuse board writing does not seem to indicate which relay cuts in the compressor clutch if one exists soley for that purpose. its the lack of wiring diagram which is really holding me up on this one/a pin out diagram on the fuse board would also greatly speed up the diagnosis time.
many thanks for any help recieved
Cj
Old 06-30-2010, 07:54 AM
Registered Cruiser
jorian's Avatar
I would PM the owner of Pelican, Wayne. He is very knowledgeable AND owns a 959. If anyone has the diagram it would be him.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 06-30-2010, 11:03 AM
Max Sluiter
Flieger's Avatar
You might try PM'ing Wayne. He is the only other one on this board with a 959.
Welcome to the 959 Registry
Pelican Parts Technical BBS - View Profile: Wayne at Pelican Parts
Old 06-30-2010, 11:05 AM
Peter Zimmermann's Avatar
This might help, let me know...
Keep the Shiny Side UP!
Pete Z.
Old 06-30-2010, 12:57 PM
You'll have to piece these together, I hope they help!
Pete Z.
Old 06-30-2010, 01:17 PM
Author of "101 Projects"
Wayne 962's Avatar
I'm working on my A/C system right now on my 959 too. There is a pressure switch that shuts off the compressor if there isn't enough pressure in the system. This may be faulty. It's labeled high/low pressure switch on the diagram above...
-Wayne
Old 07-02-2010, 01:01 AM
grateful user
don gilbert's Avatar
you can unplug the switch Wayne talked about, turn on comp. and cross the terminals with a paper clip to see if the switch is faulty. I dont know about P cars H/press. switch, but on GM cars they have a pretty good fail rate.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 07-02-2010, 07:32 AM
