Senior Member
If you are a member of the American Legion look in their monthly magazine. There is always a 20% off coupon for HF in their advert in the back. Also in some Sunday newspapers.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
fyi.... starting the day after thanksgiving the corded version of this is on sale at harbor freight for $17.87 for 3 days.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Fleabit peanut monkey
I purchased the scraper and it worked well, but its difficult to get into corners. I then purchased a 5" wire wheel (I picked it up while waiting on line at Northern Tools). What a relief! I connected it to my electric grinder and was able to get everything, including the corners. This is what I did in about 30min...
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
bump to subscribe, this project is on my list as well. Thanks!
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
I'm late to this thread, but getting serious about my '64 356. I've had a needle scaler for awhile, but had sort of forgotten about it. I tried the air version of the vibrating multi-tool. It worked OK where the undercoat was dry and brittle, but just rolled over the the softer more adhered spots. The needle scaler just blew right through everything. |
I would rather be driving
That would be a great compliment tool. This whole process is one that requires an arsenal of tools and techniques. Its just easy to DIY if you have the time and desire.
You are right. The dried stuff comes off much easier than the well adhered stuff.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I also tried the torch and scraper procedure, and it was terrible. I would not recommend. The undercoating turned into a tar and my galvanized sheetmetal is now rusted. Better off sticking with the 5" wire wheel.
Captain Annoying
Looks perfect for all the hard to get or vertical surfaces!
I found dry ice pellets was by far the easiest and fastest for flat areas though. Tip them on, wait 2 minutes, bop it off with a rubber mallet. It'd lift away in huge chunks and leave nearly no residue. |
Thanks for the multi tool tip!!
Outstanding progress on my proj |
I'll still swear by the 5" wire wheel...
...and if you work with tools for a living as I do, you buy the original, and still the best:
Fein Multimaster In addition to scraping it will cut near anything, including Arm Bushings, metal into tight corners and so on. Essential tool. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Banned
Yes, Fein is the best.
But why are you guys removing perfectly good undercoating from your car?? BMW owners would never do that. |
300hp 1800lbs is the goal
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
I'm building a race car, the undercoating is heavy. I'm collecting everything I can to get a final weigh savings number.
also, And most important is one never knows what "MAY" be lurking even under the most inocious looking undercoating...!!!
I live for 911 tweaks... |
Old undercoat removal0
Yep
All the above: Less weight= free speed Found several "mushy metal" spots easily fixed now with the car apart. Much easier to do it correct the first time. Ask me how I know.... |
Just picked mine up at HF for 14.99
Stahlwerks.com
What blade/attachment works best?
