Oh-oh don't like the look of this
Anyone else have this problem before?
![]() ![]() What goes on in there, when the engine gets partying? |
Chain fence eating turbo
A guy throws a rod out of the side of his 3.2 recently, and you are worried about a piece of plastic missing......
Sure you are going to be ok?? ![]()
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
they make duct tape in black now
youtube.com/bennyobscene |
Is that part of the cooling or intake?
1979 930 |
Registered Minimalist
That's just part of the heater system. Should be able to identify the part number via the Porsche PET catalog, then punch it into Pelican and order a replacement.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Yes, been there, patched up with duct tape and ordered a new one. P/N 96410640302 (updated from 96410640301)
Best prices are around $50- $66 or so, shop around list is $103. Guess that the rubber/vinyl type material just gets tired after 20yrs or so. That said, the new one seemed to be a bit more robust.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 09-06-2018 at 06:52 AM.. |
yup.
no wd40 to help this time ![]() qyellowperil: did you find the piece?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
I'm good with tools.
Nice perspective. I needed that this morning.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
76 911S Targa
Did something come off your alternator and punch that hole?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Still here
That piece just crumbles with old age, been there. Perhaps the updated part number
addressed that issue, who knows, but the one I replaced 4 or 5yrs ago is still pristine.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 09-06-2018 at 09:10 AM.. |
As an inexpensive option - Gorilla tape is heavy duty and it is black.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Further along I'll know more about it, further along I'll understand why
Don't know what happened, I too was woried something may have punched through it.
So I have new one coming from Pelican, about $110 total after I pay Trump off. But it's worth it not too have it "ducked up with tape". Not that I haven't used it before. I have gray duck, black duck and ape tape on hand at all times and I'm not shy about using it Thanks too all who gave there opinion. Great article on Pelican on the very problem I have with this "Air diverter shroud" Thanks for looking guys. Last edited by yellowperil; 09-06-2018 at 03:38 PM.. |
Member 911 Anonymous
Use HVAC aluminum tape for heat resistance, duck tape will just make a mess while you wait for the part, spray it with BBQ paint if you want to hide it :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
When I saw the pic, I wondered what shrapnel shot out of the plastic pipe.
1986 Bosch Icon Wipers coupe. |
Still here
It's an odd failure for sure. Did that melt away (Forget the tape !) or there's part of the shroud somewhere in the engine compartment ?
All fixed now,
With the busted air duct I'm sure the motor ran hotter and stinkier and I wouldn't recommend tape (I tried it but it just didn't look right).
Runs better now and less stinky. FWIW, my '95 993 uses a "94 964 duct", took two tries from Pelican to get the correct duct. ?? And a bunch more $$ ![]() ![]()
