Je Ne Sais Quoi = Targa
Weber IDA/IDT Question
Differences? I have the Haynes Weber manual and they do not address the issue as far as I can tell, other than to show slightly different jet sizes in the reference tables, and that the IDA is for a 911 and the IDT is for a 911T,
Thanks, Mike
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018, '81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust, Had a '71 911S Targa in the 80's, miss it, Had a '61 Roadster in the 70's, miss it also, |
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks Grady
IDT's and IDTP's used a 1.40 mm idle air bleed vs. 1.10 mm for IDA/IDS/IDAP carbs and 0.80 for 46mm IDA's. This air bleed serves the same purpose as the air correction jet for the main circuit. Most of the Weber carbs (and PMO carbs) provide for changing this air bleed but it is pressed in on the three barrel carbs.
IDT's also have an altered progression circuit from that of IDA/IDS/IDAP carbs being a leaner progression. The progression correctors may be rather easily modified into tuneable correctors. Other components of the IDT/IDTP carbs are easily swapped out. See details of the above progression circuit hole patterns and the tuneable air bleed modification on my web site. Cheers, Paul Abbott Performance Oriented
Paul Abbott Weber service specialist www.PerformanceOriented.com |
