Squeaking coming from rear shock area
Hi all,
I've had my '76 911 for about 5 years now and since I've had it, I have been noticing a squeaking/creaking sound coming from the rear shock area. The noise only happens when I go over speed bumps or when I lower the car off the jack and the rear end settles back to its normal height. Other than that, everything appears normal. I have done a search and was not able to come up with too much. I have read that the control arm bushings could also be causing the noise. The shocks are Bilsteins and look pretty old. The control arm bushings have stress cracks and look like they could use replacing. What is confusing is that the shocks do not have the tell-tale signs of being worn out (i.e. the car does not "bounce" while going over bumps). Does anyone have any suggestions of why the noise is occurring? The creaking sounds just like someone is opening an old door that has not been opened in forever. Are there any hazards to driving the car like this? Thanks!
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver Last edited by 86 911; 07-06-2010 at 09:12 PM.. |
Max Sluiter
Do you have a sway bar? Rubber anti-sway bar bushings are notorious for doing that after wearing out and drying out for a while.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
+1 on Flieger's comment. You can mitigate it by taking the stab bar bushings off and spreading a bit of lithium or silicone grease on the inside.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
I would argue that if you go to the trouble of removing them you should just replace them...they are cheap.
1988 Carrera Coupe |
Recreational User
I had exactly the same creaking noise. It was solved when I replaced my spring plate bushings and sway bar bushings with new rubber.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Bushings
And another +1...........
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Max Sluiter
Anti-sway bar bushings are easier to replace than the spring plate and trailing arm bushings. Start with the easy stuff first. Also, if you do the trailing arm bushings, you might still have squeaks from the sway bar. I did.
