964 spoiler conversion - switch p/n
I have the switch for manual control of the 964 spoiler, and an AutoLoc controller. I think I need the factory switch mount or cut-out so I can mount in my shifter console. Does anyone have info on mounting this switch in a panel?
BTW - the switch I found is 993 613 203 0001C. Socket or mount part numbers? Thanks!
1977 911S 1973 Alfa Romeo GT Veloce 1997 Lotus Turbo Esprit V8 2016 AMG C63S |
Insert Tag Line HERE.....
Senior Advisor
Yeah that part is over $200 The switch is $60! you can use a window switch mounted on the door for $12. Problem with the factory switch is it only fits in the factory mount that only fits a 964 center console. Or use a on-off-on switch mounted on the dash for a few bucks. Been there, doing that..
08 Cayenne Turbo |
@ $ 50 for both from a salvage yard.. but yes, a window switch will work.
