Zombie
Need some help
Whats this hose go too? AC I'm hoping. And where do these grounds go?? My car was in a body shop for about a year and they left more than a few things off the car.. Also I believe I have water in the fuel system as I have a awful misfire across the the whole rev band but particularly at idle. Is it safe to use some of the fuel treatment that claims to remove water from the fuel system? I may also have a bad cdi box
The Pragmatist
Old 07-23-2010, 08:57 PM
HarryD's Avatar
The ground strap goes to the engine lid. Connect to one of the bolts holding the lid.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-23-2010, 09:30 PM
Zombie
bump
The Pragmatist
Old 07-24-2010, 04:54 AM
BoxsterGT's Avatar
You are correct, its an A/C hose.
Len
Old 07-24-2010, 04:56 AM
Zombie
Thanks much, Now what to do about water in the fuel system.. Would something like the product HEET damage my car?
The Pragmatist
Old 07-24-2010, 05:01 AM
E Sully's Avatar
Your best bet is to drain the tank completely and make sure there is no rust and corrosion inside. If you don't you will just continue having problems.
Ed
1973.5 T
Old 07-24-2010, 06:09 AM
