Smartbag Porsche 911 SC
Transmission Fluid Change / Where to jack it up to do so?
Hi...I need help cause I dont feel like bringin in my car to shop for $200 bucks to change the tranny fluid.
I bought a jack and stands and SWEPCO 201 fluid. What i need to know is WHERE is the right place to jack up the car and HOW HIGH so i can get to the tranny to drain it and put the new stuff in? Thanks so much for your help. Photos would be helpful as well!
AutoBahned
use 4 jack stands & keep it level; high enuff for you to get under & do it
test it by pushing to make sure it doesn't fall and crush you & put an elevated jack, wood blocks, spare tire etc. there for it to fall on just in case it does fall |
+1 AND be sure to loosen the FILL plug first. Use the correct tool(some are socket style and others are nut style).
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Great idea...thanks thats just what i needed to know. I guess I need 2 more jack stands!
Follow my procedure here: Changing the Oil in an Early 911 Transmission
Senior Advisor
Do you know how to jack it up to those jack stands??
08 Cayenne Turbo |
