What's the Best Way to Remove & Install Heat Exchangers?
I'm about to pick up the "new" HEs from the place in Canada where I bought the 911T. And I've practically memorized Wayne's great "101 Projects" book and "Up Fixin der Porsche" volumes IX, X and 11. But I can find no recommendations on how to approach this task. What I mean is:
a) If I crawl under the car on jack stands or a lift, and spray copious amounts of Blaster and WD-40 on the 30 million nuts, I'll get most of it on me, BUT, I'd be less likely to get crud in the exhaust ports when I finally pull the headers off.
b) If I pull the engine and support it on an engine stand that allows me rotate the engine upside down, the nuts would be easier to get at, I'd get less WD and Blaster on me, BUT, all that nasty stuff would pour into the exhaust ports as I removed the headers.
c) If I was able to find an engine stand, maybe I could rotate the engine with one bank of the cylinders pointed up as a compromise.
Any suggestions here? What did you folks do?
PS: My M&K muffler was supposed to be here on the 29th but UPS got weathered out!
Tom
Old 08-01-2010, 10:01 AM
rfuerst911sc's Avatar
Unless you plan on pulling the engine for something else I vote " A ". You don't have to drown the hardware in PB Blaster just keep hitting each of the nuts several times over a 24-48 hour period. Sometimes gently tapping on the hardware with a hammer or a punch helps the penetrant get where it needs to go. As long as it's not a rusty mess you should be able to get the hardware off. If it is a rusty mess it's time for oxy/acetelyne or mapp gas to heat the hardware cherry red to remove. Take your time and you won't snap off the studs. Rush it and you'll be pulling the engine.
Old 08-01-2010, 10:20 AM
Danny_Ocean's Avatar
Not to hijack, but...leave the WD-40 for your "household projects". PB Blaster is so-so. Try using AeroKroil or acetone/ATF mix. Heat is also your friend.
Old 08-01-2010, 10:24 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Heat the nuts and bolts cherry red with Mapp gas or propane. If your fasteners are not rusted round that should do it without using PB Blaster or WD 40. However, I always spray some on after it gets red - it wicks up in the threads real good then. The penetrating fluid will start on fire but don't freak out - it burns off quick. Wear goggles as the liquid will spatter when it hits the heat.
Mapp gas is in the yellow cannister and is hotter but a little more expensive. You can use the same burning tip as you use with propane. Worth the trip to the hardware store.
Old 08-01-2010, 10:27 AM
Been here a while
I vote for another method, which is: "pay someone to do it"
my car has been out of commission with this same project, I sprayed a bunch of Wurth penetrant, Aerokroil and a couple other varieties, many times over the course of 3 days, some studs broke, some were already broken, and even with some incredibly capable extractors (fluted design from facom) that allowed massive amounts of torque, some of these studs defy removal, I've been drilling, tapping and heli-coiling for the past month or so.my car has been out of commission for far too long, I've spent a fair share on tools, parts, beers, cashed in favors from friends, you name it.
the successful removals all included lots of heat in addition to the aerokroil.
Lewis
looking for 1972 911t motor XR584, S/N 6121622
Old 08-01-2010, 10:31 AM
Danny_Ocean says:
Thanks for the tip.
All of you just Google "Aero Kroil" and go to their website. It opens to a fantastic offer on this stuff - two 13oz cans for $12 shipped!!!
Tom
Old 08-02-2010, 11:03 AM
tobluforu's Avatar
Do not forget the proper tools as well, and there is an amazing amount of threads in regards to this process. If you have a dremel, get it out and ready with a cutting wheel.
Old 08-02-2010, 12:11 PM
Formerly known as Syzygy
Canada Kev's Avatar
As well, with a project such as this, should one be prepared to replace all the exhaust studs, too (if not broken), or just use new fasteners on the old studs?
Kevin
Old 08-02-2010, 01:46 PM
Canada Kev's Avatar
Kevin
Old 08-02-2010, 02:01 PM
Been here a while
my experience was that the non-broken ones were not worth the hassle of cutting off, drilling, helicoiling.
it would have been nice to replace all the studs, but the ones that were ok, I left alone.
Lewis
Old 08-02-2010, 02:31 PM
BoxsterGT's Avatar
Porsche Crest
Been doing 911 heater boxes here in the rust belt (Northeast) for many years (since 1972). Have your 13mm 6 point socket or 8mm allen ready and use a acetelene torch w a fine tip; heating just the nut until it glows red and then quickly turn the nut. Any resistence & reheat. All other ways will end up with one or more broken studs. BTDT many times.
Theres no way you want to replace studs if you don't have to. Reassemble w new hardware & never-sieze.
Len
Old 08-02-2010, 02:39 PM
BoxterGT says:
Been doing 911 heater boxes here in the rust belt (Northeast) for many years (since 1972). Have your 13mm 6 point socket or 8mm allen ready and use a acetelene torch w a fine tip; heating just the nut until it glows red and then quickly turn the nut. Any resistence & reheat. All other ways will end up with one or more broken studs. BTDT many times. Theres no way you want to replace studs if you don't have to. Reassemble w new hardware & never-sieze.
You do this under the Porsche or with engine removed?
Thanks to all for a great discussion,
Tom
Old 08-02-2010, 04:52 PM
BoxsterGT's Avatar
Porsche Crest
Originally it was a floor jack & jack stands, now its a lift.
Doing every nut nut this way takes 1/2 hr per side to remove, less time to install.
Snap-on 13mm flex 6pt socket works well for this job.
Len
Old 08-02-2010, 05:55 PM
cjmurph's Avatar
No hijacking but I just did this with the motor on the stand and it was a pain. Pulled several studs when trying to remove the barrel and standard nuts.
The 8mm barrel nuts weren't an issue, getting to the 13mm nuts was the problem. I can't imagine trying to do that with the motor in the car. I stopped just short of cutting up a box wrench and putting a 90* bend in it. I could but the socket on them but I couldn't use the ratchet. Ended up purchasing a thin profile breaker and 1/4 turned them all the way.
Is there any advantage to replacing with allen head bolts? Have any of you replaced with something to make it simpler for future removal?
1971 Porsche 911T Targa
1986 Porsche Carrera Targa
..one of them has got to go.. decisions, decisions
Old 08-02-2010, 06:11 PM
efhughes3's Avatar
As mentioned a couple of times, heat is your best bet. Do not rely on Kroil, PB or any other spray. There is a high chance you'll be extremely sorry, and end up wishing you took this advice. Broken studs are NO fun to deal with, so do it right, with a torch.
Old 08-02-2010, 06:37 PM
jrumiano's Avatar
Get yourself a dremel tool with a flex shat and a couple of carbide bits. I recently took off a heat exchanger using this method and it took about 15 minutes to remove the heat exchanger.
here's a link that gives more detail.
Dremel your nuts... why do anything else?
Old 08-02-2010, 08:06 PM
Been here a while
the best tool for the 13mm nuts is a (1 piece) universal socket, if you use a universal joint (3/8" drive) attached to a 13mm socket, it becomes too deep, so a universal socket is the key, allowed me to get to just about every nut.
Lewis
Old 08-03-2010, 02:52 AM
tobluforu's Avatar
Lewis
What he said, and using a 1/4 inch joint attached to a long 1/4 inch extension is key.
Old 08-03-2010, 04:41 AM
tobluforu's Avatar
What he said as well.
Old 08-03-2010, 04:42 AM
grateful user
don gilbert's Avatar
if you are not going to use the old exchangers, cut them off with a sawsall about an inch or two below the flange. makes things alot easier. get 1/4 drive rachet w/swivil, a 2inch ext, a 13mm box wrench, with a bend in it will get the hard one.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 08-03-2010, 06:02 AM
