Send a message via AIM to mrtImpreza
930 turbo won't start
I previously had a thread where I was having problems with my 86 911 Turbo. I thought my fuel pumps were working but obviously not. i heard the whining and thought that was them but it was something else I was hearing. I just changed out the red fuel pump relays and instantly heard them fire up. Still no start so I pulled a plug and checked for spark but no spark. Is there some sort of safety where it senses that there is no fuel and kills the spark or what should I go about checking now that I have no spark? Thanks.
Old 08-01-2010, 02:03 PM
Is there anything that I can do now or anything anybody knows about???? Any help would be great
Old 08-02-2010, 01:53 PM
Scott R's Avatar
This shouldn't be different on a turbo, so check the green signal wire from the distributor to the CDI box. Is it brittle, or cracked anywhere? It could be that you're not getting signal from the distributor to the CDI.
I'm guessing the CDI box is working since you heard a "whining" before you replaced the relays.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-02-2010, 02:00 PM
Yeah I thought that it could have been the CDI box but I am hearing it run when I turn the key.
Old 08-02-2010, 02:04 PM
I just went downstairs and checked that green wire that goes to the distributor and it is scored with copper showing.
Old 08-02-2010, 02:10 PM
Scott R's Avatar
Well the box powering up and it sending a signal to the coil are two different things. That green wire gets its signal from the distributor to fire the coil.
Not that this is you but I had a 911 that the new owner could not figure out how to start. Turns out it had no ignition rotor inside the cap.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-02-2010, 02:12 PM
the distributor is brand new
Old 08-02-2010, 03:29 PM
I checked power at the coil and I have nothing there. Where can I go now?
Old 08-07-2010, 01:32 PM
Old 08-09-2010, 02:38 PM
Check the no start thread in the 930 forum.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/547032-sticky-common-answers-why-my-car-doesnt-start.html
1987 GP White 930
1977 Ford Bronco
Old 08-09-2010, 02:59 PM
there is a delayed ignition cut-off relay that goes bad. 12V goes through it on the way to power the CD unit. when the engine shuts off, it keeps the ignition on for a few seconds so the injectors bleed out. check for 12V at the red wire in the CD unit plug. if no voltage, check for voltage into that relay, which is the small rectangle unit mounted to the rear of the larger rear defrost relay in the engine area, left side. has four terminals and a small tube on the bottom. you can make a jumper wire with spade terminals to bypass the relay. take the plug off and jump the red wires in the plug. the pair that are closest to the engine.
206 637 4071
Old 08-09-2010, 03:51 PM
Thanks alot. I'll try it out tomorrow. Would you happen to have any pics to help me out a little more?
Old 08-10-2010, 02:08 PM
I finally ended up just buying a new ignition cut off relay and just installed it but still no 12v at coil. Any other ideas?
Old 08-18-2010, 05:11 PM
Scott R's Avatar
Sounds like the CDI is gone. It would be nice of someone else in your area could post up with a working one so you could plug it in and test that.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-18-2010, 05:37 PM
you never get 12V @ the coil. you should always check voltages around a CD system with a voltmeter or you risk damaging the CD. you do get 12V @ the red wire in the CD plug. did you test the old relay to see if it passed the 12V through it and on to the CD unit? does the unit whine? is the green wire deteriorated at the distributor plug?
206 637 4071
Old 08-18-2010, 06:17 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The only way to properly test a 6-pin CDI box (or any CDI box at that) is by having it producing a spark. The whining itself is required but not sufficient to give it a clean bill of health.
Unfortunately, with the 6-pin boxes triggering isn't as straight-forward as with the 3-pin version where you just close the points. For the 6-pin you need to provide a negative signal to the triger input. A 1.5V AAA battery hooked up reverse will do the trick.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-18-2010, 09:06 PM
ornas's Avatar
Location: Vilnius Lithuania (it's in Europe and it's not Russia)
maybe your inlet system is not hermetical, so vacuum does not pull you throttle plate down, and then your fuel pump and spark are killed, thats why it does not start. Try to remove air filter box and push throttle plate a bit, while someone will turn the starter.
at least this helped for me.
P.S. sorry for my poor english...
Old 08-19-2010, 12:41 AM
inlet system is not hermetical? could you explain more on this. thanks
Old 08-19-2010, 07:51 AM
Fuel pumps are both working. Just no spark so checked the + side of the coil and have nothing there.
Old 08-19-2010, 09:02 AM
aadrew10's Avatar
Sounds like you found your problem.
- Andrew
81SC
Old 08-19-2010, 09:32 AM
