Yep, I've done that!
CIS to Weber conversion question...
Guys,
I am gathering up the last bits to put 40 IDAs on my 2.7 CIS and I cant seem to find in the manuals the throttle bracket part that mounts to the front of the engine near the bell housing area for the throttle linkage. I am trying to figure out if the CIS one will work with the Webers or do I need to start looking for one? Thanks in advance!
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut |
You don't need the CIS throttle plate. You go from the bell crank though the engine tin to the swivel mounted on the weber intakes.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Senior Advisor
If you look at the manifolds, there is a post on the inside forward runner that will hold the bellcrank. that connects the throttle rod up frome the forward engine tin. That's all you need. you can remove the throttle console as it is not needed.
08 Cayenne Turbo |
Scott,
Thanks for your reply. OK I seem to remember this setup now. So I assume I will need a longer linkage arm?
Senior Advisor
Nope, same one.
08 Cayenne Turbo |
James,
You and I must have been posting at the same time! Thanks for the pic, OK got it....Just need to hook it up it looks like... I don't have the manifolds in hand and could not see this in the parts pics.... Thanks!
