How to gain access to replace seat belts?
Hello all,
Did some searches but didn't find the answer to this. What is the best way to gain access to the front seat belt mechanisms for replacement? Do I need to remove the entire trim panel behind the door opening? Silly question maybe but I was curious about any best practices... Thanks!
Tim in MD '86 911 Carrera Ex-'74 914, '00 Carrera, '03 C4S, '15 Macan S |
Yes, you'll need to remove the trim panel. The reel mechanism is bolted into a threaded boss just behind the door jamb.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
here is a shot with the panel and seat belt removed
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Tim, I changed both of my reels a few years back and I did not remove the panels. I got access thru the fwd edge by removing just the cover at the edge of the door and the strip at the carpet edge. It's a pain but I was able to get my wrench in there.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
when i went from stock 1977 reel to a Carrera reel and belt the attachment to body had to be slightly modified with a die grinder
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks all! Got this job done in about 30 minutes thanks to your guidance and some help with the visual.
Thanks!
Thread Tools | |
Rate This Thread | |
