After I validated the TDC mark and the case half/split are aligned, I started the engine --- first time in 2 weeks.
Again, the cold idle started ~ 500 or 600 RPM, and seem to struggle. So, once again, I turned the idle screw CC to get it up to ~ 900. Then, once the temp engine started to warm up, it settled ~ 950. That is when the engine starts to do a small hunting/surging cycle. Each cycle is ~ 10 seconds and the idle moves just a few hundred RPMs, and comes back down. Up/down between the 1K mark and the one just under it on the tach. It is certainly not the up/down by 500+ rpm every second or two type of surging/hunting like what you see here: https://www.youtube.com/watch?v=amC1UBQKZE8&list=PLemxdZbLL_s8wYIUSzgRO9L26k5lC5n1o&index=61 I will to a cold start again tomorrow to check if the idle again starts at 500 ~ 600. Quote:
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil |
When you change the idle speed it changes the idle mix. You may need to adjust once you have settled where you want to be - after you are sure you have your timing and idle speed where you want.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
@AlanL - "idle mix", do you mean the air/fuel mixture, the 3 mm allen at the fuel distributor?
Correct.
Alan
PCA Member since 1988
Not to cast aspersions, but changing the idle speed via the idle screw on the throttle housing does not change AFR on my CIS car. I would expect it to make even less difference on a lambda CIS system.
Either way, set the timing first, then adjust the idle screw, then make final adjustments to CO screw for CO%/AFR
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I am open to alternate opinions on this. But I usually find I need to tweek the idle mix if the adjustment is more than minor. It is an air bleed screw that is bypassing the closed butterfly on the intake. So it is passing more air into the intake manifold.
What would your take on it be? Regards Alan
The screw lets more/less air around the throttle plate, but that is after it was metered through the air metering unit, so it should not change the mixture, and does not on my CIS car. It is effectively the same as opening the throttle plate a tiny bit more, just more precise than an old-style throttle stop screw. And a lambda system will constantly adjust the AFR/CO% to the setting the OXS system was designed to produce.
That's if everything is ideal. However, differences between our engines, due to air leaks, parts out of calibration, etc. may result in measured differences due to idle adjustment.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 06-04-2023 at 03:44 PM.. |
You have to disconnect the Oxygen sensor from the cat in order to keep the lambda from correcting your changes. Once you’re set replug in your OX sensor
The seeking of the injection is from running too rich which is controlled by the 3 mil Allen. Once warm and running, disconnect ox sensor 3 mil Allen turning slightly CCW will cause more seeking idle, back it CW slightly to smooth idle. Once smooth, adjust the idle speed knob to set. Replug OX sensor. Bruce |
I have no experience of lambda - both my cars without. But invariably I find if I take the idle from say a lugging 600rpm to 950, I need to tweek the idle mix. But it must be for a reason other than what I had in mind. My best guess would be with the valve overlap the engine efficiency is different at 600 rpm to 950. Just went thru this process a few days ago, and did have to tweek the idle mix. Regards Alan
1982 911SC |
In all likelihood, there probably is a vacuum leak somewhere. My car is an 83 SC, stock. Owned it since 2010 and never done smoke test or chased after any hoses/connectors other than the AAR. A few weeks ago, I hand adjusted the rubber hose connecting into the AAR, and tightened the clamp a bit.
I'll need to plan for a proper smoke test one of these days.
@Alan L and @PeteKz - thank you both for chiming in and providing your thoughts on what's happening, and how to remdedy. I'll mark these posts and revisit them as I work on this issue.
I have Bentley's, Wayne's two books, and Jim's Basement Garage as resources. So will continue to study the CIS fuel system and revisit your comments. Quote:
@Bruce - thanks for chiming in and providing instructions. Very helpful. I will book mark this and revisit as I fine tune.
It has an AFR gauge, altho I have not concsiously followed this via the AFR. I will give it a shot and see what happens on the AFR. Hopefully get the car back today - getting some minor panel repair. Off o/seas tomorrow, so will try and get time to check today. Alan
