Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Uneven steering feel
The cornering feel I get from my car is different on left and right corners.
When cornering left I feel I have to pull harder on the wheel, it's like the self-centering effect is stronger on left-hand corners.
Tire wear and pressures are the same side to side.
Could this be likely a steering alignment issue or uneven shock wear ?
Old 01-17-2011, 07:06 AM
An alignment is always the starting point for steering and handling issues. Without the alignment results, we would just be wasting your time.
Old 01-17-2011, 07:46 AM
Might also check some "Assumptions"....like is the wheelbase exactly the same on the right side and left side of the car? Some cars I've checked had some surprises !
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-17-2011, 08:34 AM
porsher
aston@ultrasw.c's Avatar
X2 on getting the alignment numbers.
In my experience, big tire/service shops in the US have accurate alignment racks but they "Can't do porsches!"
Once I explain that I don't want them to make any adjustments, I just want the data they get with the program.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-17-2011, 11:24 AM
Max Sluiter
Flieger's Avatar
Shocks would not do that. I would think alignment first and corner-balance second.
Old 01-17-2011, 11:27 AM
Recreational User
porschenut's Avatar
I concur; alignment and corner balance.
Old 01-17-2011, 11:36 AM
Banned
Thanks guys, alignment will be for a start.
Old 01-17-2011, 02:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Corner Balance is a must for optimum cornering
'85 Carrera Targa
PCA/POC
Old 01-17-2011, 02:09 PM
Banned
I know there are many posts discussing this, but in a nutshell what is that corner balance aims to achieve ?
And you do it by tweaking the shocks, suspension heights ?
Old 01-18-2011, 02:38 AM
Max Sluiter
Flieger's Avatar
Ride heights.
It is like making a chair with one leg shorter than the other- not stable.
You want to distribute the weight "equally" among the tires since that gives maximum grip and the most consistant handling.
There are a few balances to shoot for:
1. Equal front weights- best threshold braking, good for dive-bomb passes while racing.
2. Equal diagonal weights- some say this gives the most consistent handling between left/right turn transitions.
3. Correct "percentages". This means that (for example) the front has 40% of the weight, and the right has 40% of the weight, so the front right weight is (2500 pounds / 4 tires ) x .4 x .4
You cannot usually get all of these at once since the mass distribution is not 50/50 front/rear- unless you have a really heavy battery, or 50/50 right/left- unless you have a passenger.
Old 01-18-2011, 11:05 AM
Banned
And what can be done to adjust the weight distribution ? How it is done ?
Old 01-18-2011, 01:48 PM
Max Sluiter
Flieger's Avatar
Ride height settings.
You screw the front adjusters up or down to change the "neutral" position of the torsion bar, and so therby how much it is strained at the ride height you want. In the rear, you need to re-index the torsion bars or else use the adjustable spring plates.
One corner gets "set" for a higher ride height and the other for "lower" and then you end up with the same total height, but different loads on the springs. You also might get uneven fender clearances.
Old 01-18-2011, 06:29 PM
