Porsche Crest Turn signal indicator light
On my 1985 911 Carrera, the left turn signal indicator lights both front and rear do not illuminate when the turn signal is used, nor does the left arrow in the dashboard light up when the turn indicator is pushed down to indicate a left turn. However, the turn signal activates right indicator lamps, and the hazard lamp switch operates all the indicator lights, including the left ones. It seems as if the problem is in the left indicator switch since the hazard switch operates/flashes all the indicator lights. Do I have to replace the indicator switch or can it be repaired if it's just a bad connection for the left turn lights? Also, is the switch a single switch behind the turn signal lever for both left and right indicators or is the left switch separate from the right switch? Once the steering wheel is removed, how difficult is it to remove or repair the switch?
Old 08-15-2010, 10:43 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
As per several posts on this subject, cleaning the switch may resolve your issue.
Do you have a Bentley?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-15-2010, 10:51 AM
muck-raker
kidrock's Avatar
jamlen,
before you inspect the turn signal stalk, make sure you check underneath the engine hood. There is a Hella engine compartment light on the hood. If it is inoperative or has a electrical short, you will encounter the exact same problems you have diagnosed.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-15-2010, 11:22 AM
Originally Posted by kidrock View Post
jamlen,
+1 And this might help.
1986 911 Targa.
Only in L.A.:
Old 08-15-2010, 11:42 AM
