Post Green Distributor Wire/Plug on '82SC
Hey Guys,
I was down to the very last electrical connection before putting the
engine back in my car. I pulled the distributor, plugged the green wire
into the side, and as I am reinserting the distributor, I hear the
sickening "crunch" of brittle 19 year old plastic.
I munged the plug.
I am sick enough of this project at this point that I almost ignored this
problem, but sanity ultimately prevailed.
I can't find any reference to this part or its number in any of my
manuals. Is this plug/wire available from Porsche or aftermarket either
one? Does anyone have a part number for me?
Finally, what does this wire do for me and is it necessary for proper
operation of my car?
Thanks!
Mark Sides
'82 SC Targa
Old 06-30-2001, 07:48 PM
Senior Member
Doug Zielke's Avatar
Post
Mark,
Part # is: 930 602 907 01
You surely do need it. It is the link for the distributor pickup to the CDI.
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
[This message has been edited by Doug Zielke (edited 06-30-2001).]
Old 06-30-2001, 08:00 PM
Post
Thanks, Doug!
Does that part include the connector as well?
Thanks,
Mark Sides
'82 SC Targa
Old 06-30-2001, 08:11 PM
Senior Member
Post
From the illustration I have, yes it does.
Old 06-30-2001, 08:16 PM
Post
on some looms, this wire is not detachable. if that's the case, it has to be cut and soldered on. use shrink tube to protect it.
Old 07-01-2001, 11:36 AM
Early_S_Man's Avatar
If you wanted an alternative to the $30 factory connector and cable, some military surplus (or IBM ... it is used in old System/360 mainframes by the mile) Twinax cable and connectors would work nicely! But it isn't a 5-minute minute 'fix' ... as it takes about 20-30 minutes to assemble one Twinax connector by hand and solder properly!
Warren Hall
1973 911S Targa
Old 07-01-2001, 12:36 PM
Post
Thanks for the replies. I'm pretty clear on what I need to do with only one question about splicing new with old:
If this wire is shielded and needs to be cut/soldered, won't there be "leakage" at that point afterwards? The last thing I want is to create an RFI problem.
Thanks,
Mark Sides
'82 SC Targa
Old 07-01-2001, 02:54 PM
