Formerly known as Syzygy
Canada Kev's Avatar
What's this on a cabrio's engine?
I've seen this on a lot of cabriolet engines, and don't know what it is or what it's for. It's the thing just left of the engine fan below the distributor that looks like a hydraulic shock or something.
Kevin
Old 08-13-2010, 04:33 PM
sudo apt-get purge 930
equality72521's Avatar
It's an engine vibration damper. AFAIK only cabs have them.
--clutch-monkey
Old 08-13-2010, 04:37 PM
Now in 993 land ...
aigel's Avatar
More flex in the cab chassis - this will avoid that the car twists into a pretzel when you hit the accelerator.
George
81 SC (sold)
Old 08-13-2010, 06:11 PM
efhughes3's Avatar
Yep, that is a cab item. Except, every once in a while you'll see a transplanted motor with this mount, which is always a clue to what had the motor before.
Old 08-13-2010, 06:19 PM
Canada Kev's Avatar
Just how flexible are these things and how much could that little piece correct? I won't likely see any track or even AutoX use, but most certainly will get some spirited street driving. I've read stories about targa flex when on a lift or sloped driveway or similar. I just don't want to be driving a wet noodle, especially when I upgrade the engine. Though they DID have 930 cabs...
Kevin
Old 08-14-2010, 08:53 AM
efhughes3's Avatar
No insult, but I don't think you will be able to overdrive the car. Cabs and Targas are just fine for trackdays or canyons/mountains.
Old 08-14-2010, 11:49 AM
Canada Kev's Avatar
No insult taken. My skin is a bit thicker than that.
I didn't think i would be able to, but stories of overly flexible cabs and targas had me a bit concerned.
Kevin
Old 08-14-2010, 04:51 PM
MBruns for President
JeremyD's Avatar
don't believe everything you read.
Old 08-14-2010, 05:42 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Arrow Yeahper...
That is how easily you can ID a cheap Cab conversion...
If it`s not there, it`s definitely not an original Cab...
Who Will Live... Will See
Old 08-14-2010, 06:55 PM
Canada Kev's Avatar
But it was on the internet...
Kevin
Old 08-14-2010, 07:41 PM
JJ 911SC's Avatar
Well that change everything... It must be true
Old 08-15-2010, 03:18 AM
JJ 911SC's Avatar
Question Say What...
... I just don't want to be driving a wet noodle, especially when I upgrade the engine. Though they DID have 930 cabs...
Just came back from Track time at Mont-Tremblant. She definitely did not perform like one.
I hope she will not see the comment... Check post # 1 to she what happened last time she got pissed off It Was an Accident Waiting to Happen...
Old 08-15-2010, 04:09 AM
I am pretty sure that Cabs came with stiffer engine mounts than the coupes. Its a popular upgrade on coupes to upgrade to stiffer mounts to the same ones cabs came with standard.
What do people think would be the impact of removing this dampener on a cab.
Also potentially putting solid engine mounts in?
Old 08-15-2010, 03:37 PM
Thats a shock absorber only avaiable from Porsche. I know since I bought the last one at the time. About $95.00 but whats money. I don't think they avaiable anymore , if so please post.
Kepperly
87 slant nose turbo look carrera cabriolet
Old 08-15-2010, 11:57 PM
JJ 911SC's Avatar
Arrow Correct name is Vibration Damper
Kepperly
$84.25 right here... Pelican Parts - Product Information: 911-375-175-00-OEM
Old 08-16-2010, 01:53 AM
wdfifteen's Avatar
It's meant to dampen higher frequency "twists" than anything you'd see on a track or on a lift. More like keeping the door windows from vibrating from a rough running engine.
Old 08-16-2010, 05:39 AM
kuehl's Avatar
I deleted the 'vibration' shock when I modified my cab's engine and everything is fine without it.
Old 08-17-2010, 04:39 AM
gtc gtc is offline
abides.
gtc's Avatar
I thought it was a damper meant to reduce engine vibration for increased comfort. Cabs are typically more of a cruising car than coupes or targas.
Coupes and targas have basically the same body structure but targas don't have the damper, so the body flex idea is out.
Graham
1984 Carrera Targa
Old 08-17-2010, 11:33 AM
Canada Kev's Avatar
What are the differences in body stiffening between coupe/targa/cab?
Kevin
Old 08-17-2010, 12:02 PM
Jack
I was curious, so I took mine out to see how much resistance there was. Mine may be shot, but I can't see what good, if any it actually does. Seems like someone had a great idea that in reality isn't needed.
If, when I do an engine drop, I get a coupe mount. That stupid shock gets in the way.
-Jack
85 Carrera Cab
Old 08-17-2010, 12:07 PM
