Formerly known as Syzygy
What's this on a cabrio's engine?
I've seen this on a lot of cabriolet engines, and don't know what it is or what it's for. It's the thing just left of the engine fan below the distributor that looks like a hydraulic shock or something.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
sudo apt-get purge 930
It's an engine vibration damper. AFAIK only cabs have them.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Now in 993 land ...
More flex in the cab chassis - this will avoid that the car twists into a pretzel when you hit the accelerator.
![]() George |
Yep, that is a cab item. Except, every once in a while you'll see a transplanted motor with this mount, which is always a clue to what had the motor before.
Just how flexible are these things and how much could that little piece correct? I won't likely see any track or even AutoX use, but most certainly will get some spirited street driving. I've read stories about targa flex when on a lift or sloped driveway or similar. I just don't want to be driving a wet noodle, especially when I upgrade the engine. Though they DID have 930 cabs...
No insult, but I don't think you will be able to overdrive the car. Cabs and Targas are just fine for trackdays or canyons/mountains.
No insult taken. My skin is a bit thicker than that.
![]() I didn't think i would be able to, but stories of overly flexible cabs and targas had me a bit concerned.
MBruns for President
don't believe everything you read.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
83 911 Production Cab #10
That is how easily you can ID a cheap Cab conversion...
If it`s not there, it`s definitely not an original Cab...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
But it was on the internet...
Well that change everything... It must be true
I hope she will not see the comment... Check post # 1 to she what happened last time she got pissed off ![]() ![]() It Was an Accident Waiting to Happen...
I am pretty sure that Cabs came with stiffer engine mounts than the coupes. Its a popular upgrade on coupes to upgrade to stiffer mounts to the same ones cabs came with standard.
What do people think would be the impact of removing this dampener on a cab. Also potentially putting solid engine mounts in? |
Thats a shock absorber only avaiable from Porsche. I know since I bought the last one at the time. About $95.00 but whats money. I don't think they avaiable anymore , if so please post.
Kepperly 87 slant nose turbo look carrera cabriolet |
I deleted the 'vibration' shock when I modified my cab's engine and everything is fine without it.
abides.
I thought it was a damper meant to reduce engine vibration for increased comfort. Cabs are typically more of a cruising car than coupes or targas.
Coupes and targas have basically the same body structure but targas don't have the damper, so the body flex idea is out.
Graham 1984 Carrera Targa |
What are the differences in body stiffening between coupe/targa/cab?
Jack
I was curious, so I took mine out to see how much resistance there was. Mine may be shot, but I can't see what good, if any it actually does. Seems like someone had a great idea that in reality isn't needed.
If, when I do an engine drop, I get a coupe mount. That stupid shock gets in the way. -Jack
85 Carrera Cab |
