www.ALBERTOBILLA.it
RSR TwinPlug
how many deegre of advance must do with 3.0 Carrera distributor (6 pin cd box) modificated to twinPlug ??
www.ALBERTOBILLA.it
Is it even possible to run a twin plug setup off an SC CDI box? I run about 32 degrees at 3000+ on my Electromotive crankfire twin-plug setup but I have no CDI and no distributor..
Gary R. |
With your 2.8 the best way to figure the correct timing would be on a dyno. I can tell you that with my 2.7 twin plug short stroke with 10.66:1 compression and using 2 Bosch 6-pin CDI's and a converted 3.0 distributor I found that 24 degrees @ 6000rpm was perfect with my engine on a dyno.
Mark Jung Bend, OR MFI Werks.com |
www.ALBERTOBILLA.it
type of Cams?
I installed a set of GE 60's. Intake-266 duration/.490" lift; Exhaust-248 duration/.455" lift with a lobe center of 102 degrees.
I would rather be driving
I run 26 deg on my 3.2SS.
The advantage of twin plug is not having to use as much advance.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
25-26 degrees with RSR Sprint cams and 10.5:1 CR. Your fuel will dictate optimal timing with your engine.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
www.ALBERTOBILLA.it
my compression is 11.3:1 i use 110 octane gas...28° @ 6000
Thats just fine.
