o2 Sensor Help
So I installed a new exhaust on my 1980 SC.....however when I went to switch the O2 sensor from the old cat to the cat bypass I noticed the O2 sensor was never plugged into the car......it had just been lying there connected to the cat and nothing else. I have been searching the forums looking for where the o2 sensor gets plugged in to and how but I haven't been able to find it......can someone help??!!
grateful user
its a strange looking conn. in the engine bay, left side close to you cdi box, mounted on a metal bracket, if its still there, it has a yellowish tint to it.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
thanks!
