Yep, I've done that!
joeblow's Avatar
Wireing Gurus or Sages, HELP!!
I am basically ready to fire my 5 year nightmare project (details soon to be told to the list), but I have a wiring issue.
The car is a 71' T and the engine is a 76' 2.7 CIS, BUT the CIS is gone and Webers are in it's place. I found some good info on the differences between the 14 pin connectors for both engines and have made the modifications needed there (pull two out and dis-guard and move one). What I have not found is info on the remaining plugs I have to hook up.
I have Workshop manuals in electronic format but they are not the best for electrical diagrams as they are on two pages and sideways!! I am unable to print them either since I am in the process of moving and my printer in in a container on the ocean.
I am running out of time to fire her up and could use some help guys.
Enclosed are the two connectors I am concerned with. The first is a two prong connector that has a matching on on the chassis which I assume belong together but I have visions of making smoke signals with that assumption so I wanted to get verification first.
The second is a little worrisome as I think it might be non-original? It looks like an H4 connector to me and has very non-Porsche colors (all solid). Can you guys confirm this is not a Porsche engine connector?
Assuming I am correct in the above statement, on an early car with carbs besides the 14 pin, there is just the CDI connector (3-pin plus ground) and the above mentioned 2-prong that come from the engine to the chassis?
I also enclosed a pic of two identical connectors coming out of the rear fuse panel area. One I am 90% sure is for the two stage rear defrost (shown plugged in), any ideas on the other one?
Last question. The 71' has a pin called Distributer signal on the 14 pin connector, no such match exists on the CIS harness. Can anybody tell me what that is for? I have two wires for the coil and two for the distributer inside the harness which seems to be what I need. Therefor I am not sure what this connection is for.
Thanks guys!!
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 09-19-2010, 07:09 PM
CIS to carbs wiring questions.
This might help.
Good Luck, Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 09-20-2010, 02:31 PM
joeblow's Avatar
This might help.
Good Luck, Shane
Shane thanks for the link. I still am not seeing anything reference the small two pin connector. It has a pairing on the chassis but without more info I am concerned about hooking it up.
My situation is a little different then taking a running CIS car and converting to carbs. I have a 71' getting a 76' CIS engine and engine harness and converting to Webers.
Old 09-20-2010, 06:41 PM
Joe,
Please post a pic if you can. What colors are the connectors, do they match?
Shane
Old 09-21-2010, 06:39 PM
kens_74_911s's Avatar
Hey Its Ken
I did the swap in my 74 911S stripped all the CIS wiring and went with only what is needed for Webers + a few spare options. 1 Change is got rid of the silly out dated wiring panel and used a rear wiring panel from a 76 914 parts car I had. It came out clean since the connections (large multi pin in /out) match. The wiring traces are all potted on back side and I have an extra relay or 2 available. You may not want to do all that but I did break down all the ins and outs and sketched it on the a copy of the 914 panel from manual if it helps. I also broke downthe main connector pin outs, Less the CIS. Maybe that’s all you need.
The 914 panels are not that expensive and clean things up back in engine compartment. I can send a Pic if you or anyone else wants to see how it looks
and scan some diagrams (hand drawn on the 914 panel drawing from manual useable) if you need. I really wanted to put them on CAD since I do that and maybe should... just added a "quick fire"non mechanical point ignition so it needs that updated anyway.
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 09-21-2010, 07:23 PM
14-pin wire connections for '76.......
Thanks guys!!
Joe,
Without the picture/s it would be difficult to solve your problem. If you have been using the 14-pin connection guide (Dipso's thread post #29) supplied by James Brown, pin#12 (free) is actually the connection for tachometer and CDI @ TD. Is the black/purple wire in the engine harness (14-pin) located @ 12? If not, then this could be your question. Post some pictures for better communication. Keep us posted.
Tony
Old 09-21-2010, 07:33 PM
