I OWN A 1988 PORSCHE 930. THE CAR TURNS OVER BUT IS NOT CRANKING.IF I KEEP TURNIG THE ENGINE OVER AFTER A WHILE THE CAR WILL START. WHEN I STOP AND TURN THE ENGINE OFF,I HAVE NO PROBLEM RESTARTING THE CAR.I THOUGTH MY PROBLEM WAS THE FUEL ACCUMALATOR.SO I REPLACED THE FUEL ACCUMALATOR THINKING THAT WAS THE PROBLEM. BUT AFTER REPLACING THE ACCUMALATOR I STILL HAVE THE SAME PROBLEM.SO COULD I HAVE A BAD FUEL PUMP? YOU SHOW WHERE THE FRONT PUMP IS LOCATED BUT NOT THE REAR ONE. DO YOU AHVE AN ARTICLE SHOWING THE LOCATION OF THE REAR ONE? THANKS.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Fuel Pump Replacement
Old 03-20-2011, 11:23 PM
Author of "101 Projects"
Wayne 962's Avatar
The fuel accumulator works in conjunction with a check valve located within the fuel pump. If this valve is faulty, then the car will have difficulty starting, particularly when it's hot. You might want to investigate the pump as a potential issue here.
- Wayne
Sirius Driver's Avatar
Hopefully its just the check valve. I replaced mine but to avail. Now I'm sure its the acummulator.
1982 RoW 3.0 911
1999 996
Old 03-21-2011, 10:46 AM
Can the check valve be replaced separately from the fuel pump? I saw (what looks like) a fuel pump near the steering rack. Is that the only one?
Old 03-29-2011, 02:46 PM
You sure can.
1982 RoW 3.0 911
1999 996
Old 03-29-2011, 06:41 PM
Check this thread.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/547032-sticky-common-answers-why-my-car-doesnt-start.html
1987 GP White 930
1977 Ford Bronco
Old 03-29-2011, 07:08 PM
I read the thread "Sticky for common answers..." and it doesn't mention the check valve. I also searched and read a few other articles, and didn't see any examples. Also, I searched on Pelican for the part, and didn't find a check valve for my car. I have a 1981 911 SC Euro (3.0L CIS). Thanks for any suggestions.
Old 03-30-2011, 12:44 PM
Somatic Negative Optimist
Gunter's Avatar
Sounds like ware has a cold-start problem since he has no problem restarting hot.
Does a '88 930 have CIS? If so, I'd check out AAR, AAV, TTS, CSV and WUR?
Old 03-30-2011, 01:30 PM
All the 930's had CIS, yes.
Old 03-30-2011, 05:05 PM
HarryD's Avatar
Sure does sounds like a Cold Start Valve problem.
When I accidentally disconnected my CSV a few years ago, it was incredibily hard to start until I reconnected it.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-30-2011, 06:31 PM
Heh. I drove my 930 for some considerable time without the thermo-time sensor connected at all - thus no CSV. Tried several times, but you just cannot reach the darn thing with the intercooler hard pipe in the way. And I really didn't feel like taking the intercooler off...
When it got to be winter, it still started fine like that with ice on the ground/windows. So I stopped caring. Hood shock clips were easy, electrical portion of the ignition switch was a pain but doable, the TTS connector was just impossible to reach and re-connect with the motor in the car and the intercooler on...
I'd be inclined to suspect/check the Cold Control Pressure first.
'77 S with '78 930 power and a few other things.
Old 03-31-2011, 12:31 AM
Residual fuel pressure.......
Check the residual pressure and start from here. Beside from the typical problem with the FP check valve and leaking FA causing low residual pressure, a leaking fuel distributor's relief valve could also contribute to this problem. Test and confirm.
Tony
Old 03-31-2011, 06:00 AM
RETIRED
Joe Bob's Avatar
Fuel pressure, CHT and WUR are cold start issues. Check valve is usually hot start.
2012 ML350 3.0 Turbo Diesel
Old 03-31-2011, 07:14 AM
