Hodgey's Avatar
Question Passenger Power Window Struggles
Hello all.
My passenger window struggles to close up when it gets to about 3/4 of the way up when the door is open.
It stops when it gets to the same position when the door is closed, and I have to help it up by hand or stop and open the door, so I wonder if there's an alignment issue. I have tried to adjust the positioning using the correct bolts but I end up putting it back where it came from as it makes the problem worse.
I've read posts on the spring retaining pin shearing, and I did find one of these in each of the door pockets when I bought the car last year, but I cant think the window will work if these are broken off, although it does make sense that if the spring is not helping the window up then it will be more difficult for the motor.
The drivers window works flawlessly
Any ideas at all?
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 08-29-2010, 12:53 PM
Pw
Seems like Porsche's have slow power windows.
My 1977 911 they work fine but man are they slow.
My 1982 924 was similar on both but now the passenger really moves.
Lost the power lead so I put a new circuit in off the battery and it flies up/down
Old 08-29-2010, 02:17 PM
KCinBR's Avatar
I had the same sort of problem with my 88 Targa, I replaced the felt channel peice and lubed the pivot points on the mechanism and now it goes up with no problem...still kinda slow but much smoother, check out this post for more info:
Window guide (felt) and slot seal replacement coupe
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 08-29-2010, 03:06 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Keep us posted as to your resolution. I can smoke two cigarettes while the passenger window goes up on my 81.
Old 08-29-2010, 03:22 PM
Hodgey's Avatar
Okay fellas.....have the felt seal in hand, going to tackle the job in the next couple of weeks.........
Neil
Neil
Old 12-09-2010, 07:07 PM
The passenger side on my 87 was slow and intermittent too. I repaired the switches, realigned it and used graphite on the runners all to no avail. What I finally tracked it to was a really tight main pivot on the regulator. I used lots of light oil and worked the window up and down repeatedly by applying power directly to it from a battery charger. It's still slow but at least it works now.
Old 12-10-2010, 02:27 PM
puddy's Avatar
Hah this is 6 years old and I see now follow up post on a resolution. I have a really slwo passenger window too, my car is a 1975 with an original passenger door and a 964 drivers door, the drivers window goes up fast, the passenger is slow and need help for the last 2 inches. Does the 964 have a better/faster window motor? Should I bother trying to fix my slow passenger window?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 04-22-2016, 04:54 AM
Hi Puddy, You might want to check the power window fuse. Slow windows or wipers are often caused by a bad fuse.
Old 04-22-2016, 07:19 AM
puddy's Avatar
OK, i'll look into that fuse but my old hotrod is missing many wires in the fuse panel and some things don't seem to line up with the factory diagrams.
Cheers, Chris
1986 951
Old 04-22-2016, 09:27 AM
Cars Ruined My Life
impactbumper's Avatar
I ran into this today. When the door was open the window would go significantly faster than the door closed. I pulled the door cards, cleaned the rails and inspected the regulator. All seemed to be fine. Channel where glass sits was removed and cleaned and glass went back in using proper agent, kept it overnight to dry.
Upon further investigation I found the problem was the door. When **** it would push the window frame out and when the window rolls up the glass would catch on something preventing to go up/down quickly.
I went ahead and pulled the window frame, installed it back realigning properly. Adjusted the door. And the glass would raise lower super quick like as it should.
When you shut your door pay attention to your window frame. If it is pushing out as the door closes you will run in issues.
I guess this helps a bit!
Old 04-22-2016, 05:13 PM
puddy's Avatar
That's a great suggestion, I'll look to see if my frame is out of line.
Thanks!
Cheers, Chris
1986 951
Old 04-22-2016, 07:30 PM
