Speed sensor and reverse light switch
So this past weekend I got some work done on my 78/81 FrankenPorsche... unfortunately it was all steps in the wrong direction (got everything put together and found a gas leak) so took the engine out and pulled the fuel lines. In the process I found that the speed sensor cable had been pinched, and one of the wires was damaged. is that something I can cut and then splice back together? would that damage the integrity? normally I'd just cut my losses and replace it, but my budget went out the window...
Also I had damaged the reverse switch's cable the last time I took it all apart, took probably two inches off of it when I spliced it back together (someone had fun with the tolerances at the factory) Before I rip that cable apart, is there any way to get a new one? does it come out of the wiring harness relatively easy?
Hopefully you all had a slightly more productive weekend than I.
George
Old 09-08-2015, 07:20 AM
El Duderino
tirwin's Avatar
Contact Dennis (timmy2). He made me a new engine and CIS harness. My reverse light switch connector was in bad shape. He has a source for the terminals so surely he could make you up a little extension for that.
Not sure about the speedo sensor but he can probably help with that too.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 09-08-2015, 08:10 AM
awesome! thank you, also nice picture
Old 09-08-2015, 08:29 AM
also, how do I find timmy2?
Old 09-08-2015, 08:31 AM
sorry, found him
Old 09-08-2015, 08:38 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by ritter4242 View Post
sorry, found him
Timmy2 for sure. I despise those little reverse switch plug-in terminals once they start to go south.
I believe the speed sensor just delivers an electric pulse that needs a good path. Are either of the wires shielded with a mesh type wrap?
1981 911SC Targa
Old 09-08-2015, 09:55 AM
Bob, I'm not entirely sure, I know that the Brown (I think) wire got cut, but it looked like there were two other wires in there as well (both white, could have been a nylon support cord). worst case scenario is I just snip the thing in half and find out that there is shielding. I wouldn't be out anything as the one is already cut.
George
Old 09-08-2015, 10:50 AM
scarceller's Avatar
If during the repair the wires are soldered and shrink tubing is used I see no reason why they can't be repaired. If exposed to water I also like to put RTV clear silicone inide the shrink tubing prior to shrinking it, then cleanup the excess RTV and you have a water tight wire repair.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-08-2015, 11:03 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, just a magnetic pulse signal wire, no critical current passes thru it. Heck I attached my GPS to it on the gauge side. Yes I have two speedos now
'85 Carrera Targa
PCA/POC
Old 09-08-2015, 11:38 AM
scarcellar: Thanks now I just need to patch my reverse light /: haha
Draco: that sounds amazing!
Old 09-08-2015, 11:47 AM
Still here
pmax's Avatar
Seriously !
Isn't this just a simple low voltage on off switch ?
What is the deal with the flimsy connectors and the "kilovolt" hard but brittle bakelite material for the plug ?
Old 04-22-2016, 08:07 PM
