new member
mdmiller911's Avatar
Bilstein strut play...safty issue?
I noticed a bit of play when checking the drivers side wheel bearings but when I removed the bearings and checked out the races, they both looked good. Checking further, I grabbed the strut and the movement, from what I thought, is from the upper mount. I searched the forum and found that I probably need new bushings in the insert. So my question...
I have a DE on Wednesday and don't want to miss it. Is it safe to run with the strut like this? Keep in mind that there is only a little bit of play and no clunking sounds coming from the front end.
Thanks, Mike
77 911s 3.2
944 track beater
58 TVR Grantura MkI vintage racecar
Defender 90 NAS
73 CB750 Cafe
Old 09-04-2010, 10:21 AM
My struts have tape in them to build up the bushings and keep things straight. Seems to work fine. I'm sure your struts are safe as is.
-Andy
Old 09-04-2010, 09:03 PM
new member
Thanks Eagledriver
Any suspension experts care to chime in?
Thanks, Mike
77 911s 3.2
944 track beater
Defender 90 NAS
73 CB750 Cafe
Old 09-05-2010, 06:35 AM
Mike,
No safety issues here,....
All you'll get is variable camber with worn bushings.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-05-2010, 08:42 AM
Sboxin's Avatar
Recommendation for strut bushing replacement (when you decide you need it):
Craig Garrett (G2 Performance)
5424 Greenboro Dr
Grand Rapids MI 49508
garrett@iserv.net
He charged $100 +shipping with a 2 day turn around time
And his bushings are wider than Bilstein
Take care,
Roy Turner
Old 09-05-2010, 09:23 AM
new member
Great to hear...Thanks Steve
When I'm ready, I'll give Craig a call. Thanks Roy
77 911s 3.2
944 track beater
Defender 90 NAS
73 CB750 Cafe
Old 09-05-2010, 11:06 AM
