Never Replace Another Hood Shock
I have finally found the supplier of a great device that fastens to the old worn out hood/engine gas shock and holds up them. It is made by Pylon and it is call the lift lock. I have had one one my SC for 8 years without a problem. Check it out
Rick T |
Hood Shock
Do you have a link?
83 911 Production Cab #10
... and voilas; Advance Auto Parts: LIFT LOCK by Pylon - Part 8200
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Checked out
Being plastic, I wonder if it is designed to break before the hood bends, if someone tries to slam the hood shut. That would be a great design.
80s Ferraris have a mechanical type strut, it's like the regular porsche one except it mechanically "locks" in place. You have to push a ball in to release it. You see a lot of those cars with "kinked" hoods! |
It looks a lot like a lift lock I had on my 68 for years. Worked like a charm until the body shop, not knowing the trick, snapped it. I was surprised, because I really didn't think it would break.
So now I just replace the struts from time to time...but maybe it's time again.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
i just have a pvc pipe cut to length over the shock.
the same idea but cost zero as i had pvc left overs in my garage... the pic below is BMW E30 but i also have it on one of my front hood shocks on my 84.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Banned
Roller blinds for a Targa top ??
In my unrelenting quest to improve a perfect design (Targa
), I was thinking if there was an easier / quicker way to provide some temporary cover when the targa top is off. I know about the Carbrella but I would like something snappier...What about fixing a couple of spring loaded roller blinds below the Targa bar that when extended would lock into some hooks on the windscreen rail ?? It might look naff but it would get some protection from the sun, bird drops and prying eyes... Any thoughts ? |
Banned
sorry, wrong thread !!!
Make Bruins Great Again
***Advance has 20% off anything thru this weekend and there's no shipping charges if you chose to pick it up at the store. Just picked one up today.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Wash. State
I put one of these on; piece of cake, works great!
Happiest when Tinkering
+1 this is on my project list with pelican front and rear.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Just put the Lift Lock on today. Doesn't add weight, no holes or mods to the stock car, simple to use and works great. Best of all, there's no prop rod to bang into while working on the car. Thanks for the suggestion speedman.
I'm not knocking any of these solutions, but there is a very easy way to replace the front hood shocks - just leave off the bottom clip. The spring force of the shock will hold it in place just fine (I've had mine like this for over 200k miles).
Hope this helps, Chuck.H '89 TurboLookTarga, 320k miles |
Sherwood Lee's company (pelican member and all around good guy)
Seine Systems > Welcome
72T Sepia, Irish delivery car ; '16 Cayenne Gone ... 73E Targa - Grey/Beige ; '90 964 C2 - Samtrotmetallic (Gina, the Lipstick Lollobrigida) |
muck-raker
thanks for the link...put on a new Lift Lock last week, and it works great!!!!
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
J.J.
19 years and 17k posts...
I just went to my local Advance Auto Parts and bought 1 of the "Pylon Lift Locks" for $12.89. That's all they had in stock and they didn't expect to get restocked. The part # is 8200 and it's made by Pylon Mfg. in Deerfield Beach, FL 33442. It's raining, so I may try to install it today...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I just installed the Pylon mechanism, we'll see how it holds up...
Under the radar
I've been using the same idea on my engine cover. I use a stiff piece of rubber hose with a slit cut down the side so I can slip if over the shock. If I forget, the rubber hose just pops off.
