LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Spiderman
Jesse16's Avatar
Count me as a fan of regular hood shocks. Open hood and done, no second step required. Let go of the hood anytime, no crashing down on your head. My replacement units have been in for 5 years and counting, replacement is easy.
I did try the prop rod and its simply in the way and not secure at all when stowed or up. Like others say, one of the more sanely priced replacement parts. Get the good ones front and back.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 01-08-2015, 04:46 AM
Discseven's Avatar
Originally Posted by Trackrash View Post
I've been using the same idea on my engine cover. I use a stiff piece of rubber hose with a slit cut down the side so I can slip if over the shock. If I forget, the rubber hose just pops off.
Nice one Gordon. Gona look for some hose now!
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 01-08-2015, 04:54 AM
There is someone on Pelican who makes aluminum hood props with a spring loaded lock pin. I have them and so does a friend. Purchased very recently. They work well. I can't remember who makes them. I will check records for a name. I believe I paid by check. Maybe he will see this thread and reply. He makes a good solid product.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 01-08-2015, 05:07 AM
Straight shooter
Lapkritis's Avatar
I always kept a 3 wood in the car before I put new hood shocks in.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-08-2015, 05:21 AM
I did an engine drop last winter and after getting hit on the head a few times I swore I would replace those dampers when done. I took them off and they still seemed really strong.
Spring came and they worked great through summer and fall.
I'm not sure if borderline ones fail in colder weather, or if they were designed to operate best within a warmer temperature range and a lighter tail -turbo tail probably heavier). I really didn't want it to be harder to lift in the summer since I open to cool after a spirited drive and leave it open to cool.
I seem to see these replacement threads come up when the weather turns colder.
Old 01-08-2015, 05:52 AM
Here you go:
FS: Mechanical Front Hoot Struts
The guy has even posted a video of how they're made...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-08-2015, 06:06 AM
KTL KTL is offline
Schleprock
KTL's Avatar
$75 each for the aluminum mechanical struts? Wow........ I know aluminum is not cheap these days. But we can accomplish the same for less with a dead one, a drill and a bolt. To each his own, as they say.
I made a prop rod like Seine's from a piece of threaded rod (covered with some rubber hose and an inexpensive light duty spherical rod end from McMaster.
Kevin L
'86 Carrera "Larry"
Old 01-08-2015, 06:19 AM
Fb = M/S
aoncurly's Avatar
I've got 4 years on these SS Weltmeisters and they are still going strong:
Weltmeister SS Hood Struts - Lifetime Warranty
1981 911SC, Guards Red/Black Leather
2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics
2017 Tesla Model X
Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E
Old 01-08-2015, 06:30 AM
Im ok with my gas struts but if I were you guys Id get the mgb struts . The MG midget ones look shorter so maybe those will work better. I would bet the mgb ones can be cut down if needed. The old jeeps used them on the hard tops and they work great. They are better than what you guys are doing because you dont have to reach in and manually release them you just lift up the hood a bit and it releases the catch. Atleast thats how the jeep ones work im not positive about the mg ones.
Old 01-08-2015, 07:07 AM
At the risk of repeating myself, I've owned 8 or 9 911's over the last 35 years and I can count the number of struts I've needed to replace on one hand and still have fingers left. If you guys are replacing them repeatedly, it's probably becuase the struts you are buying are aftermarket crap. I only used the original Porsche parts and those would go decades in use. Then again, I didn't open the engine lid or trunk every day, although when I started using battery tenders, the trunk got opened twice every time I drove a car.
JR
Old 01-08-2015, 07:11 AM
Originally Posted by LIVEVIL View Post
I may go with the Seine systems support.
I looked it at too but it says it can only support 25 lbs. Not sure how much my tail weighs. Will look into it but this may work.
Old 01-08-2015, 07:48 AM
Model Citizen
herr_oberst's Avatar
JR
Because strut replacement is expensive, and the lower clip on the front hood is a bit of a pain to replace, I try to remember to let the struts do the work, rather than pulling up on the hood to get it to open faster. (like I used to do. Maybe I'm the only neanderthal out there who did this...?) I don't know if it helps them live longer, but it makes me feel better.
Old 01-08-2015, 08:14 AM
Straight shooter
Lapkritis's Avatar
JR
There's a pretty cool how-to out there about wiring up a magnetic Apple charger:
VWVortex.com - So I kinda spoiled the bedlined Audi.
Old 01-08-2015, 10:06 AM
