Banned
Fuel distributor rebuild
I'm curious... as my FD will probably have to be rebuilt soon, I wonder if removing and fitting it is a job within reach of most of us... how hard it is ?
Senior Advisor
There is a lot of high fiddle diddle stuff in there that needs special tools. If you just want to open it up and clean it, there are a few who have tried it (do a search). Best just to get a rebult unit and exchange.
08 Cayenne Turbo |
prebordao,
Are you asking if it is difficult to remove it and then replace it with a rebuilt one? In that case, it's fairly easy. Just unbolt the fuel lines that run to it, and it comes off pretty easy. There's not a lot of room, but it can be done. When you are removing it, be careful that the plunger doesn't drop out of the bottom - it does not like to be dropped.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Crotchety Old Bastard
R&R is very easy. We handle rebuilds if interested.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Banned
I'll not attempt to rebuild it ! Can it be done without lowering the engine ? I'm also afraid that when you lift it from the throttle body, all those springs and o-rings come out, or are they fixed in place by the diaphragms ? |
I have done mine a couple of times without lowering the engine. It's tight, but not too hard.
Becarefule NOT to drop the plunger there is no stopper. It a tight squeeze. I just removed mine, The eight small fuel lines can be removed with little difficulty, Than the two big one are more difficult you need to remove the U rubber as there is not enough clearance than the three screws on top with i used the head of the screw driver and connected it to a torque wrench. very little working space. according to the porsche worshop manual you should remove the hex screws on the AFM and remove the whole unit together but it's up to you.
1983 911 SC |
Here's the best thread for the fuel distributor. He does the rebuild, but you can see what the fuel distributor looks like.
CIS fuel distributer cleanout w/pics Picture of the airbox with fuel distributor attached: ![]() Picture of just the fuel distributor that you will remove - it's held on by only 3 screws and an "O" ring at the bottom.
Banned
Thanks for the pics, great help !
And what about rebuilders that you had good experience with ? I've been looking at the info on the SpecialTauto site, but would like to hear from "real" customers... |
