try going to control panel and open "folder options" and look through the file associations in the "file types" tab once it has populated them all.
you should find JPG and JPEG in the list alphabetically and you can choose the default program for opening them.
import and or restore them if they are missing, disabled, or corrupted.
Google the problem and you will find lots more help...
Old 09-10-2010, 01:51 PM
AutoBahned
RWebb's Avatar
you can also manually edit the file name
Old 09-10-2010, 02:09 PM
Arnage
Arnage's Avatar
Wayne:
I do not care how you do it or what you do it with, I really apprecaite this great (AND FREE) website for all us Porsche-types to buy/sell/trade as well as share thoughts and ideas. I also apprecaite your fine parts service. I thank God there is someone like you serving the Porsche Community.
Sincerely, Art
Old 09-10-2010, 03:28 PM
Max Sluiter
Flieger's Avatar
OK, I am going to stop the hijack.
As my closing remarks, manually editing the file name does not work. I can go through the roundabout conversion process, though.
I tried the file default program association thing- did not work.
I took a chance and did some Vista updating, including an IE upgrade- did not work, brought my computer to the brink of destruction. An update for my mousepad thing failed and I was dead in the water until it re-installed the drivers itself.
I had turned off updates after my last round 5 months ago resulted in no sound working on my computer.
Don't you love Microsoft Vista?
Old 09-10-2010, 04:07 PM
I only get bitmap in the drop down menu. I used to have options, the first one being jpeg. If I try to name the file "file.jpg", it end up as a bitmap file "file.jpg.bmp"
You could try a system restore if there is a restore point date before something changed a setting in the registry causing this. That should bring it back and it won't remove any of your data. Windows update will redownload any critical updates if there were any again.
i'm using XPpro sp3 so it's a little easier..
Old 09-10-2010, 04:26 PM
Max Sluiter
Flieger's Avatar
I might try that, but I have not done anything to the system settings in the timeframe where this change occurred. No updates, either, until today.
Old 09-10-2010, 04:46 PM
Metal Guru
911nut's Avatar
Originally Posted by Wayne at Pelican Parts View Post
After watching the stats on the server, I believe that all speed issues are fixed. If someone is still experiencing slowdowns, then my best guess is that the problem is with their connection, or with a route from their ISP to the co-location center at USC (where the servers are located).
-Wayne
Funny you should say that, Wayne. Just tonight, I waited far longer than 10 seconds to load a page from PP. However, the mail order side of your system is lightning fast. BTW, the P/P bb is the only site I visit that has loading problems.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-10-2010, 06:25 PM
