72' 911S
Show Me Your MSD Setup!!
Hi Everyone -
I'm installing a new MSD box and I'm wondering what the best mounting location is. Wayne's book says to try and mount it where the old box was, but there's just no room there for this monster MSD box. If I move the box to any other location I run out of wire for the battery ground. I also have to use the Tach Adapter. I was thinking of mounting that where the old box used to be and mounting the MSD box directly in the middle of the firewall between the shock towers. Please post pics of your MSD setup so I can get a better idea of where to mount. Thanks in advance! |
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold |
Mine fit in the stock location just fine.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
on the firewall
SWB 911S 1967 307653S in my fathers garage now LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon |
Senior Advisor
It will fit fine in the old spot if you remove the rear defroster relay and place it under the electrical console.
08 Cayenne Turbo |
19 years and 17k posts...
Looks great!
Looks great! You might want to move the coil to the firewall... Excellent looking engine!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
72' 911S
SCrescue -
Did you mount the box directly on the frame rail or on the firewall? If on the curved frame rail between the shock towers, how did you do it? Thanks! |
1982 911SC 1987 924S |
Between the shock towers...
![]() Lindy |
Any more pictures with the twin plug setup? I'm adding the the twin plug dist in the next few months. I currently have one MSD/coil running one set of plugs and the other plugs are just waiting for the new dist.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Banned
Not the best photo, but mines on the left. Same location as the old one except mounted horizontally. The plastic tray cover covered about 1/2 the MSD so I cut it down to where the whole thing is exposed. I think it looks better.
You might not need the tach adaptor. There is a wire that comes from the old unit and I think it is purple and black. Don't remember for sure ,but one of these other guys should know. Put a female spade connector on that and it plugs directly into the end of the MSD unit. It worked for me, but don't know about your set up.
MSD 6A Mounting............
Here is what I did:
The alternator has an internal regulator and I rotated the rear window relay 90 degrees so that it lays flat. That left plenty of room for the MSD unit. I put male spade terminals on the MSD wires and simply plugged them into the 6 wire master plug. That way, If I ever decide to go back to the Bosch unit, it will simply plug in as before. Hope this helps.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Stay Cool !!!!!!
![]() Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
cole... doesn't the sound from the 6AL's drive you crazy? I put mine under the drivers seat and I'm starting to regret it.
85 930 Ruf BTR |
BTR,
I'm older than dirt so it's not an issue; I can't hear it !!!! Cole
Found a pic of the MSD wiring and harness pigtail installed.
![]() ![]() Cole
