-   -   Can a 911 be made to handle as well as a Spec Miata? (http://forums.pelicanparts.com/porsche-911-technical-forum/565596-can-911-made-handle-well-spec-miata.html)
Kemo 09-21-2010 08:48 AM
I've been to a few DE's now and made some very interesting observations... Spec Miatas seem to do a better job at the track than 911s (especially my 911) in the tight curves. Obviously, the Miatas are low on power but man do they handle well. I also understand that alot depends on the driver, and Im not that great of a driver.
But given the same driver skill, can a 911 be built to handle as well as a Spec Miata?
JerryL 09-21-2010 09:07 AM
You are kidding right??
Regards
Joe Bob 09-21-2010 09:09 AM
Getta 914.....
Scooter 09-21-2010 09:10 AM
Originally Posted by jerryl (Post 5573196)
you are kidding right??
+1
Dantilla 09-21-2010 09:40 AM
I race a 944, whose track performance is very similar to the Miatas.
Both the Miata and 944 are very easy cars to drive. A novice can jump in and feel like Mario Andretti.
The 911 is quite different. A novice 911 driver will be frustrated until learning how to use the 911's idiosyncrasies to his/her advantage. After that, nothing touches the 911 on the track.
Keep driving!
Trackrash 09-21-2010 09:42 AM
OK. What about a 911 vs a Boxter? At a recent DE I noticed that a couple of Boxters I followed both were noticeably quicker through the tight turns.
OK, gurus is this the way it is? Are our torsion sprung 911s just going to be inferior in handling to the newer cars?
Say it's not so.
AirKuhl 09-21-2010 09:57 AM
I tracked a Miata and a 993 at Laguna Seca for several years. In the Miata you almost keep it floored the whole way around, the handing in the corners is wonderful and forgiving, although it has basically no power. In the 993, you had to drive the car at all times. They are both tons of fun but in different ways. A Spec Miata does 1:46's at LS. A stock 993 does 1:49's. A modified 993 can do 1:41's. Sorry, no NA torsion bar 911 data as I've never tracked one. I'd guess 1:5x.x mostly stock but can get into the 1:3x.x's heavily modded.
tobluforu 09-21-2010 10:14 AM
My old 911 is/was pretty well prepared for auto-x at one time, and I consider myself a pretty good driver, but doesn't everyone? My brother had a Miata that was pretty well setup (i'm a better driver than he was) and there was no way in hell I could keep up with that damn car at times. Super frustrating. Before that, he had an older crx and that car rode like it was on rails at times.
grudk 09-21-2010 10:19 AM
From what I've seen, a spec miata can outrun a normally-aspirated torsion bar 911 3.0/3.2 in stock or lightly-modified form on a tight track. With 'prepared' class cars and up, the 911 should take the flag
Flieger 09-21-2010 10:20 AM
I think an old 911 can be just as fast around twisites as a Spec Miata- if it has monoball bearings everywhere, is lighter, has stiffer torsion bars, better dampers, and sticky tires. At which point it is not so much an 'old 911'. How does a stock Miata compare to a Spec Miata?
The other thing is that even though the 911 can be as fast through the turns, the driver of the 911 will be working much harder
Those Honda S2000 are what gets me. They seem to keep up so easily. Not necessarily pass, but keep up- like Jeremy Clarkson in the Mistu Evo VIII chasing the Lamborghini Murcielago.
crikett 09-21-2010 10:33 AM
Can't claim to be an expert with the 911 at the track, and even less so with the Miata... but I'll throw out my observations from my limited experience.
Given a similar level of prep, the Miata and later torsion bar 911s (SC and 3.2L) are really similar. Overall I'd expect that the 911 would be just a little faster... but over a field of drivers, you'd probably find a much wider range in the 911s than the Miata (more of that "the Miata is easier to drive").
The Miata is better balanced and the chassis much more rigid, and the suspension wasn't designed in the early 1960s. These are big advantages for the Miata. The 911 has more power and is much more demanding on the driver. I think the brakes on the 911 are better as well, but I'd call it a toss up as the Miata's strengths seem to allow it to get really deep into corners and turn in sooner.
The key to having a 911 handles like a spec Miata is my earlier statement about similar level of prep... a spec Miata is a race car. Admittedly one that still retains many stock elements to help save on cost, but it is a race car and race cars tend to go really well in the turns. Taking a 911 and going with ARBs, monoballs, bigger torsion bars, and similar prep that goes into that spec Miata should yeild a car that is potentially a little faster than the Miata (though it can be a little depressing just how fast those Miatas are given how little power they have!).
aston@ultrasw.c 09-21-2010 10:35 AM
I had a student in a Cayman and he rode in my 911, 3.2 w/Elephant goodies.
He observed, "My car may be faster but you are having much more fun!"
5String43 09-21-2010 10:41 AM
Re torsion bars vs coils - why this distinction in this thread? They both do exactly the same thing in exactly the same way. They're both cylindrical steel used as a springing medium. The only difference is that one is straight and one is coiled. What am I missing here?
Superman 09-21-2010 11:00 AM
Which is faster, a Miata or a classic 911? It depends.
5:04 09-21-2010 11:37 AM
I just sold a 200whp Miata that I was building for RTA to pick up my "warmed up" 911.
My first impressions were that the 911 handled very well, it just didn't seem like it was handling well. I'd have to actually look and see how fast I was going since it felt so on edge and composed (makes no sense I know) I didn't feel like I was going that fast. The Miata always felt fast
The Miata was a car that anyone could drive fast. The trans is easy to use, with the turbo and a weight of around 2100lb wet it was very quick in a straight line and I had 225 A048's square. BC racing coilovers with a range of other goodies. It was a car that could be driven very easily very quickly. I never got the chance to take it out to the track since I sold it right after building it due to the 911 bug biting, but the average Miata of that build will be about 3-4 seconds faster than a Spec Miata.
The MAJOR short coming of the Miata is that any track with any sort of straight kills it. You may be faster than every car in the corner but "races are won in the straights". My current 911 would blow the doors off of a spec Miata in the straights and probably handle closely if not as well while still keeping up with my turbo Miata and probably on par for times.
Also the Miata made everyone feel like they were Ayrton Senna. My experience with the 911 is that unless you get either 60-70% or 100% out of it depending on your driving skill.
I got back into a Miata last Sunday at a bmwcca Auto-x I was instructing, and that reminded me that in Auto-X the Miata is king.
Kemo 09-21-2010 11:45 AM
maybe what I am witnessing is the ability for people to come up to speed really quick in a Miata, which is easier to drive, while im still learning how to get my 911 around the track without spinning out. Quite humbling IMHO, and a bit frustrating.
JeremyD 09-21-2010 12:03 PM
Just more time behind the wheel Kemo - and you'll start being able to use the 911's disadvantages to your advantage.
Driven well, you should be able to get the 911 rotated and on the power much earlier than a Miata through a corner.
But as supe says - it depends - on the level of driver, the level of car prep, the distance between the corners...
AirKuhl 09-21-2010 12:08 PM
Not much difference. The engine is basically stock although it can be blueprinted. 1.8l cars must have an intake restrictor plate. Stock exhaust except cat can be removed. Shocks can be updated to a specific aftermarket one but no geometry changes. dot-r tires. Safety gear. Minimum weights enforced with ballast as needed. That's pretty much it.
Trackrash 09-21-2010 12:13 PM
It's the fact that when Porsche went to coil overs they modernized their suspensions. Less camber and toe change during cornering.
jwakil 09-21-2010 12:40 PM
One thing all those other non-porsches mentioned can't do is give three of your friends a ride while auto-xing. The other thing is you are comparing 1970s-80s technology to 2000s. A third thing is you can't compare different drivers in Auto-X. A good driver with any kind of car will beat a lousy driver with the best car.
Superman 09-21-2010 01:09 PM
jwakil is absolutely correct. A talented driver in a pickup truck can beat a lot of Miatas.
Coils can be progressive. Torsion bars cannot. Modern suspensions have 3....maybe four pickup points. Far more effective than older 911s. Porsche went as far and did as much with those older suspension setups as anyone could, but it's still a bad design compared to modern suspensions. Polishing a turd. You get a really shiny turd, but it's still a turd.
Spec Miatas are 2100 lbs? Sheesh! Build a 2100-lb 911, and see what happens. As Dan says, once a guy knows how to drive a 911, they will clobber a Miata. Go Dan, go!
Oh, and for the guy who thinks Miatas are AX bullies.......I guess you need to need to see some 914s driven properly. We can accommodate you at our PNWR AX's.
racerfink 09-21-2010 03:07 PM
Just to clear up a little bit of info on here about Spec Miatas.
My 1990 is a 1.6L making 112hp at the rear wheels. It's got 197k on the odometer. The original motor was in it for the first two years I raced it, but started showing signs of "Short-nose crank syndrome" common in '90's. The fastest I've gone around Sebring is a 2:40.0. The track record is 2:36.1. Most National level cars run about 120hp at the wheels for 1.6L's, and 130hp at the wheels for 1.8L's (with air inlet restrictors). I mostly finish in the top ten at SCCA regional events that avg. 35 cars in SM. It weighs 2275lbs. with driver, and we have to run on Toyo RA-1's (205-50-15), usually shaved down to 4/32nds.
the NA Miata's ('90 to '97) have very little in the way of torsional rigidity. The hardtop and rollcage do A LOT to change that. My '90 street car felt like the front end and back end rotated seperately around the transmission tunnel until I got a tower brace for the seat belt towers.
The suspension is mandated by MazdaSpeed. It consists of Bilstein shocks that are stock on the '99 Miata sport package, with Eibach springs rated at 700lbs front and 325lbs. rear. The sway bars are Eibach pieces as well. We do run a collared shock body that we can change the spring pre-load with.
While you will be closer to a top time the first time you get in a Spec Miata vs. the first time you step into a 911, they aren't exactly easy to get great times out of, especially if you run the 1.6L. The 1.8L's have more torque, by far, and are a little easier to drive. The biggest problem people have the first time they try one out from another type of car is, they ALWAYS miss the 2-3 upshift, and get fifth instead. If you try to man-handle them, you'll lose time.
racer 09-21-2010 03:21 PM
Of course a 911 can be made to handle better.. but it will cost nearly as much as a spec miata ;)
CMDR Perry 09-21-2010 03:34 PM
911 VS Spec Miata
To repeat essentially what others have said you would have to spend a lot of cash to make a 911 work as well in the corners. I have Autocrossed my SC locally for almost 5 years. The car is well prepared and somedays I flog the hell out of it but it is still 3 seconds behind modern Japanese cars on a 60 second course.
The 911 SC just has too many age related flaws; Torsion bars, 915 gearbox, CIS, etc. The Miata is front mid-engined and copied the Lotus Elan backbone chassis. There are literally dozens of them at every event up here and they all go like stink into 3rd gear. Look at Dfinks car now for sale, that thing is loaded for bear and he has decided he cannot compete in X Prepared on the National level.
If you want a car that is easy to drive fast then a mid engined car is the only way to go. This is one reason why 914's always beat up on the 911's at the Parade.
But If you want a lifetime challenge get a 911 for sporting events.
Flieger 09-21-2010 06:34 PM
http://forums.pelicanparts.com/uploa...1285119269.jpg
:D
Scooter 09-21-2010 06:43 PM
You guys do understand that there is a HUGE difference between DE (track) and AX....right?
Joe Bob 09-21-2010 07:19 PM
Yeah, one is racing......:eek:
skinnerd 09-21-2010 08:00 PM
A lot of what makes a Miata so fast in the corners of a race track and at autocrossing is physics.
Or more clearly....lack of weight.
Most 911's are tanks compared to Miatas.
Stock Miatas weigh considerably less than a stock 911.
On a race track a reasonably powered 911 should smoke a Miata down the straights.
It's in the corners where the Miata advantage lies.
Light weight, neutral handling, a modern suspension.....all add up to a car that is easy to drive.
Anyone can jump in a Miata and drive fairly quickly.
The same cannot be said for a rear engine (heavy) 911.
However, that is what makes a 911 so satisfying to drive....it does take a little skill to drive one.
Once weight transfer is understood and mastered, there is not a funner car to drive than a 911 I think.
Don't be too down on your 911.
With a few suspension upgrades, the handling of a 911 can be brought up to a level near that of a much lighter Miata.
The good thing is that you are driving a 911, and not a Miata in the end.
The 911 will always look better, sound better, etc, etc than a Miata.
JMHO:p
BGCarrera32 09-21-2010 08:42 PM
It depends a lot on the track. Take a spec Miata up to BIR in Minnesota where the main straight is almost a mile long and turns 1 and 2 are 110+ mph, and a Miata will be quickly outgunned.
smokintr6 09-21-2010 09:06 PM
I'm going to throw my vote in with the "more seat time" crowd.
My torsion bar car "out handles" my stock '99 miata. Now whether it develops more mechanical grip, I dunno. But it transitions with the throttle in ways my miata could never hope to accomplish. The only suspension mods on the 911 are stiffer torsion bars and Koni shocks... and it has some weight out of it (2750 full fuel).
5:04 09-21-2010 09:40 PM
I still stand by it despite someone elses personal experience or two. I've seen Miata's in all trims wreck shop at Auto-x's, and IMO the Miata is one of the best Auto-x cars you can buy. Light weight, amazing suspension, easy and cheap to modify, fun!
Don't me wrong though, I'm saying this applies specifically to Auto-x. Although like every car there are exceptions the 911 should easily out run a Miata like for like. And when I say like for like I mean modified to similar trims and with equal drivers.
I also sold the Miata and bought the 911 for performance reasons too. Although the Miata is one hell of a car it is a limited chassis. Why do you think you don't see many major time attack Miata's. There are a few but for them it's all based on what track they're on rather than being able to be consistently dominant. I got rid of mine since I don't really care for Auto-x and on a road course the 911 is a better choice and more fun. Again this doesn't mean Miata's make bad road course cars since I personally know 3 that run sub 2 minutes at Buttonwillow #13.
Originally Posted by Flieger (Post 5574254)
He had the second fastest time of the day IIRC lol
I mentioned both
And finally, no Miata will ever look as good as a 911 :D
Flieger 09-21-2010 10:33 PM
I can't figure out how that air dam stayed on the rear deck with those little tab mounts. I sure does look home-made. He did not even seal the bottom of the spoiler thing to the rear deck.
tobluforu 09-22-2010 04:25 AM
But... at the end of the day I will take my 911 over a miata anyday. Even though my brothers Miata was tricked out, when I borrowed his car for week my friends gave me the biggest ration of ****!
DanielDudley 09-22-2010 05:45 AM
Very few people run 911s at SCCA national events. You will see at least 50 Miatas. They have double A wishbones front and rear, coilovers front and rear, and 50/50 weight distribution. You have more driving options in a Miata, and sure they are easier to drive. The fact that they are inexpensive doesn't make them cheap.
One thing that hasn't been mentioned about 911s here is that they are totally geared wrong for a tight track. You will not have any power at 25 MPH in second in a slow corner, so all that fantastic grip is really not exploitable. If you gear a 911 like a Miata, it is going to feel and do much better on a tight course. Even so, if you want to be competitive, you need to pick the right tool for the job. But then you are going to be running against the very best drivers, some with many years of experience. The top five guys are all going to be within a half a second of each other.
Once I got past the humility of not having the best car or being the best driver, I started getting into the fun of driving again, and the challenge of being a better driver. Practicing car control, going fast, having fun. Doing my personal best, and getting the best out of my car isn't going to happen if I'm not having fun.
Try to have fun and play with the car. If someone offers to ride along, say yes. If someone offers you a drive, say yes please. I can always tell when I am having a good day, because of the stupid grin.
GrantG 09-22-2010 06:33 AM
My 73 911 (heavily modified) passes Spec Miatas on the straights and corners very easily (as well as some other Very expensive hardware)...
at7driver 09-22-2010 06:40 AM
as mentioned earlier the miata may be quicker, I had a 1994 I autocrossed and I drove it way harder than any of my 911's. The 911's however were much more satisfying to drive.
Similar to a 916 Ducati and a newer R1 (or take your pick of current liter bikes from Japan).. the Japanese bikes are generally faster than the 916's but you can't park them in your living room and drool over them like you can the 916..
There is something about driving the 911's that you can't get from any other car. The 911's are, well they are Porsche 911's. nuff said.
Kemo 09-22-2010 06:54 AM
DanielDudley brings up a good point about the gearing. In the really tight sections of the track, I seem to have ZERO pickup where the SMs just pull right along. Like they are a couple of thousand more RPMs up there. Im basing alot of what im talking about here from driving the L1 track at Driveway Austin. Its a super tight track with the car constantly loaded down. Perhaps I should start to experiment going to lower gear in the tight sections to see if I can get the pickup and go. I also agree that more seat time is always helpful...I guess we can always revisit this topic a year from now and see how I feel then :)
911st 09-22-2010 10:31 AM
Flieger,
This is what I was talking about as to camber curve and caster on another thread. On a strictly race car we want these to be more stable to under different conditions (banked / off camber, short long turn...) we still have the tires at there best angle to the track.
I suspect 911's need a lot more rear tire to come close to matching the potential of a a miata in rear tire to weight.
Assuming a 2000lb Miata with 205/s at 50/50 distribution. That is 1000lbs front and 1000lbs back.
Assume a 911 at 2500 lbs with 40/60 distribution. That is 1000 front and 1500 rear.
To equal the grip of the miata we would need something like 205's front and 300's rear.
For fun lets look at a GT#-RS. I would think with a driver they would come in at about 3300lbs, have close to 40/50 distribution. Thus have about 1320 lbs front and 1980 rear.
It would need about 245's front and 405's rear. They run 245's and 325's.
This is all very simplistic but it looks like a Miata with 205's might even have more tire than even a GT3
Flieger 09-22-2010 10:41 AM
You want camber recovery. If you have no roll that means no camber change. If you have lots of roll that means lots of camber change.
The complicating factor is how soft the suspension is because the camber recovery depends on body roll but the total roll of the wheel/tire assemblies can only happen after the body has rolled so there will be pre-mature camber recovery on a softly sprung car. However, if the car is too stiff there will be insufficient body roll to cause the needed camber recovery in steady-state turns.
As is the case so often, the softer car will have more total grip available in a steady state turn but the stiffer car will have the advantage in quick transitions.
burgermeister 09-22-2010 02:08 PM
What's camber recovery? Or do you mean camber compensation, ie the amount of camber change you get from x degrees of roll?
