WUNDERWAFFE
JINKATIN's Avatar
Loud Pop
Hello everyone,
I need help!
When driving at a low rate of speed approx. 5mph and turn the wheel to the left, I hear a loud pop. It is not a clicking sound or it does not make multiple popping sounds it is just one pop every time. It sounds like it is coming from the front driver side but not definitly sure. Has anyone experience this or know what it could be? Any and all responses are greatly appreciated.
Charlie
1986 Carrera
Old 03-16-2010, 11:40 AM
wheel bearing
Old 03-16-2010, 11:43 AM
WUNDERWAFFE
JINKATIN's Avatar
So, to replace the wheel bearings do I have to do both front wheels and howdifficult is it to replace them? Do I need any special tools? Sorry for these dumb questions, but my knowledge of these things are limited.
Thank you
Charlie
1986 Carrera
Old 03-16-2010, 12:04 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thank you
Lots of posts on this subject.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-16-2010, 12:39 PM
WUNDERWAFFE
JINKATIN's Avatar
Thank you, to all who have responded.
Charlie
1986 Carrera
Old 03-16-2010, 12:53 PM
KNS KNS is offline
This may not be your issue but I had a similar problem recently. When making a left turn followed by a right turn, I would hear a 'pop' sound. I could swear that from sitting in the driver's seat that it was coming from the right front area of the car, obviously from changes in the suspension/load while turning. I could duplicate it nearly every time.
Turns out that it was the right rear sway bar drop link that was loose. Tightened it up, 'pop' all gone.
Kurt
Old 03-16-2010, 02:09 PM
WUNDERWAFFE
JINKATIN's Avatar
Thanks KNS, I'll try doing that first.
Charlie
1986 Carrera
Old 03-16-2010, 03:05 PM
Milo2361's Avatar
i had this happen as well, it was my steering wheel bearing, the bearing on the lower half of the shaft, to get to it i went through the smugglers box.
1998.5 Ram 2500 Cummins
Old 03-16-2010, 05:55 PM
WUNDERWAFFE
JINKATIN's Avatar
Thanks Milo2361, will check that as well. Milo how difficult was that to replace?
Charlie
1986 Carrera
Old 03-17-2010, 08:31 AM
Milo2361's Avatar
not terrible.
when i started it i went about it all wrong(looked in all the wrong places, etc)
just takes some working to get it to come out. if i remember correctly you might have to remove the lower U joint to get the bearing removed. you'll see when you look in there. - the bearing is in a shaft that sticks up from the bottom front of the smugglers box. - if i had known then what i know now it probably would be an hour tops. cant remember if i bought the new bearing from here or from somewhere else but it was in the range of $50.
when i popped the bearing out it fell apart - - totally rusted. after the pop it was near impossible to make a turn.
Old 03-17-2010, 05:51 PM
WUNDERWAFFE
JINKATIN's Avatar
Well I replaced the wheel bearings, sway bar tightend, and I still have that popping sound problem. I was told that it was my steering rack, there was some play and pop coming from the driver's side. Does anyone know of a place here in the southbay area who can rebuild it?
Thanks,
Charlie
1986 Carrera
Old 04-29-2010, 04:48 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Jinkatin - Please stop trying to fix it by listening to people throwing out wild guesses here and bring it to someone trusted in your area before you go flying off the highway. You replaced the wheel bearings? Why? How do you "tighten" a sway bar?
Gary R.
Old 04-29-2010, 05:20 PM
WUNDERWAFFE
JINKATIN's Avatar
Yeah, I know but the the bearing needed to be replaced. About the sway bar I meant all bolts are tight. I'm taking the car in to the mechanics' tomorrow morning, and have him figure it out.
Thanks gary,
Charlie
1986 Carrera
Old 04-29-2010, 05:44 PM
WUNDERWAFFE
JINKATIN's Avatar
Sorry for the delayed response but I finally found out what was causing the popping sound, It was my right strut.
Charlie
1986 Carrera
Old 02-20-2011, 03:08 PM
First, glad you found the problem.
Second, glad you took the time to post the cause/cure! It's very frustrating when we never know which, if any, of suggested remedies is the correct one. Your simple posting will, no doubt, help guide others who have a mysterious "pop" when turning.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-20-2011, 05:23 PM
WUNDERWAFFE
JINKATIN's Avatar
Thanks Ossiblue, I hope this does help someone.
Cheers,
Charlie
1986 Carrera
Old 02-20-2011, 05:52 PM
Tule Tom
I had a loud pop when I turned and it turned out to be a broken mount on the rear swaybars. Get your flashlight and look around.
Tom
88 carrera targa
Old 02-20-2011, 06:52 PM
Max Sluiter
Flieger's Avatar
Uh, he found the problem: the strut (bearings, I assume).
Old 02-20-2011, 08:22 PM
RETIRED
Joe Bob's Avatar
The big three of noises when determined from the rear end.....most common to least.
Sway bar bushing/broken mount. Popping, sighing, grinding.
CV joint, clicking on turns, grinding, thumping and in bad cases....no power to wheels.
Wheel bearing, whirring noise going up and down with wheel speed. Grinding and a squeel....
2012 ML350 3.0 Turbo Diesel
Old 02-20-2011, 10:00 PM
WUNDERWAFFE
JINKATIN's Avatar
It was the spindle on the strut. Anytime I turned the hub would slip out and make that popping sound.
Charlie
1986 Carrera
Old 02-21-2011, 10:25 AM
