Tired Member
DaddyGlenn's Avatar
It is alive!!
Still much to do. But this made me
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 12-27-2015, 06:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #241 (permalink)
MBruns for President
JeremyD's Avatar
Woo Woo!
Old 12-27-2015, 06:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #242 (permalink)
timgt3's Avatar
I've been following your thread for years. Those seats are stunning. Congrats on firing her up.
Old 12-27-2015, 07:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #243 (permalink)
Tired Member
DaddyGlenn's Avatar
Thanks Tim. I wish it hadn't taken so many years. But sometimes life does get in the way.
Getting the engine running has been a huge motivator. This weekend I moved to the front of the car and got all the under fender stuff installed.
I installed the horn upgrade kit from our host. I haven't tried it yet.
Ran new hoses for the windshield washer system and got the tank installed. I'll have to fabricate a new mount for the washer pump as I had to remove the old one to install the oil cooler duct. I decided to disconnect the headlight washer system, for now. I didn't work before so I won't miss it. I'll add that to the things to fiddle with after it is back on the road.
Today, I turned my attention to the front valance. And I took time to snap a few pictures for you.
This is where I started this morning...
I temp mounted the valance using small c-clamps. Marked a couple spots to drill holes in the bumper for the mounts. Off with the valance, drilled the holes then added a strip of thin neoprene to serve as a buffer between the valance and bumper.
Then the valance went back on using a couple M6 bolts through the bumper with fender washers on the fiberglass side. While I was lying on my back trying to hold the valance and install the bolts, I realized I should have just drilled and tapped the bumper instead through bolting it. I am not 100% comfortable with spreading the force over just the two attachment points in the from (either side of the oil cooler) and where the sides connect to the fenders. So I will add additional connection points across the bumper. Drilled and tapped, of course. And after the heck of a time I had getting the valance attached, anytime it needs to come off in the future, I will remove it and the bumper as a unit. It will be much easier that way.
This bolt was a real challenge.
Valence installed
So with the valance on, I put the screen over the oil cooler inlet and installed the accordion rubber pieces.
Had to trim the valance on the passenger side a tad. The pelican I purchased the valance from had already done the driver's side.
Had to run out to Home Depot to get some hardware to install the screen and really fiddled with that for a good bit of time. I'll grab some black model paint and hit the hardware. Not real jazzed with the silver hardware on the black screen.
Here is the end of day picture..
Now I have to try to remember how the lights and turn signals go in.
Glenn
Old 01-03-2016, 03:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #244 (permalink)
GaryR's Avatar
Send a message via ICQ to GaryR
Way to go Glenn, almost home!!
Gary R.
Old 02-18-2016, 04:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #245 (permalink)
Tired Member
DaddyGlenn's Avatar
Thanks Gary!
I guess an update is in order.
I've made a bit more progress. Had a setback while installing the headlights. did something stupid and had to replace one of the lenses. That was a task I hadn't done before but a relatively easy one, once I had the part. I've got some electrical gremlins in the turn signals. I'm thinking it is a relay, but I have just added that to my list of things to troubleshoot later.
I've pretty much finished at the front of the car, minus a couple annoying details. And now I am focused on some under car items.
Today, I've connected and adjusted the clutch cable and was about to install the axle assemblies when I discovered that I hadn't purchased new bolts and washers. Which is why I am here at the computer.... to spend a little more.
I think next on the list for today will be to assemble and mount the rear bumper and perhaps the engine lid.
Here are a couple shots of where she stands now.
Glenn
Old 02-20-2016, 09:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #246 (permalink)
Occasional User
Cook&Dunning's Avatar
Great work Glenn: I have been following this from the start. You are keeping your project moving forward way faster than I have - very impressive work. Great attention to detail; love the color, it is a great car. Congrats, it looks like maybe the finish line is not that far away.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 02-20-2016, 09:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #247 (permalink)
NoMoreALFAmac's Avatar
what an awesome job you've done .... Very inspiring!
Old 03-06-2016, 10:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #248 (permalink)
Tired Member
DaddyGlenn's Avatar
Look what just came back from Allegheny Metal Finishing....
Powder coated satin black. Tires get mounted on Friday.
Glenn
Old 05-04-2016, 05:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #249 (permalink)
Horrido's Avatar
Nice work
You are never too old to have a happy childhood.
Old 05-05-2016, 01:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #250 (permalink)
Derek911's Avatar
Looking at how many years this project has gone on I wondered if some of us just like working on projects? 6 years is a long time, but why do we take on these projects? I mean, it's a car, and do we get the most enjoyment out of driving it or working on it? I love driving my car, but I also love working on it. But sometimes I think we let projects take large chunks of our lives. Sometimes I have to stop and tell myself not to do it... Not just with cars, but with things around the house as well. I love projects, but the satisfaction and frustration is a love hate relationship. After all this work I really hope you get to enjoy driving it. Hopefully you won't get it so perfect that you won't want to drive it.
Old 05-05-2016, 02:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #251 (permalink)
Tired Member
DaddyGlenn's Avatar
I have been working on it. I just haven't taken the time to share any update. So this is where I am. With the completion of the carpet install today, my list of big things to do is done!
Now I just have a long list of little things to correct or complete. Nothing on that list is necessary for me to drive it.
It is registered. I've reactivated the insurance and all it needs now is an alignment and to pass the state inspection.
Here are a few pictures:
Glenn
Old 09-25-2016, 04:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #252 (permalink)
JeremyD's Avatar
Love it!
Old 09-25-2016, 04:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #253 (permalink)
Tom '74 911's Avatar
Fantastic job Glenn. I remember when you started this thread... a few years ago now... way to stick with it! It looks really great!
Happy driving!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-25-2016, 06:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #254 (permalink)
Tired Member
DaddyGlenn's Avatar
Thank you gentlemen. I have owned the car for about 12 years and this reconstruction has taken up the last half of that time.
I have learned so much. I could not have do it without the encouragement and tutoring of those on this board. The next time I take on a build like this, it will be easier and take much less time.
Glenn
Old 09-26-2016, 02:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #255 (permalink)
CBRacerX's Avatar
Looking great! Well done getting to the 'finish line"
Old 09-26-2016, 03:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #256 (permalink)
Mo money = mo parts
Hats off to you Glenn for amazing perseverance. Most projects like this get sold as a 'project'. Quite an accomplishment for a single person.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 09-26-2016, 04:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #257 (permalink)
911 tweaks's Avatar
looks greeeeat glenn...!! nice color combo & contrast...
tell us how she runs after you are on the road for a bit and get a minute...
way to see the project thru...!!! enjoy... bob
I live for 911 tweaks...
Old 09-26-2016, 09:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #258 (permalink)
78-911SC's Avatar
Greg is that a shot over the bow in regards to Glenn being single? Ha. Definitely more difficult with a wife or kids. Great job no matter the circumstances.
PJ
78 911sc Targa
70 911T
Old 09-26-2016, 10:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #259 (permalink)
Tired Member
DaddyGlenn's Avatar
Yes, I have a wife and 4 kids (now 14, 16, 17 and 20) and they each did their share of keeping me away from the project. And I had several self-inflected household projects, too. But I can be pretty tenacious.
Glenn
Old 09-26-2016, 02:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #260 (permalink)
