Tired Member
DaddyGlenn's Avatar
I really didn't want a project this big....yet...
Time to start the project thread. I had intended to rebuild the suspension, make the exhaust legal, fix a coupe rust bubbles and a few small while I'm there tasks.
That was before I found this..
and this..
and this..
And some other ugliness.
So the project has grown. In addition to the tasks listed above, this thread will cover an windows out repaint, the addition of an IROC style whale tail, a refresh of the interior and some fancy front and rear bumpers (haven't decided what style yet) and probably a lot more while I'm in there stuff.
I'm going to need to learn a lot on this one. Definitely stepping outside my comfort zone.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 09-25-2010, 01:59 PM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
I feel ya, one of my own personal cars is being torn down bare chassis.
I have a trickle or little bit of rust I had found. It's important to go over things with a methodical and sharp eye. No where to the same extent as you have, but the trickle could mean more. I can't risk it.
Good luck man.
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 09-25-2010, 02:05 PM
Tired Member
DaddyGlenn's Avatar
This was the tip of the iceberg, so to speak.
I knew there would be more but geeez...
Glenn
Old 09-25-2010, 02:23 PM
Any time you have rust like that in your last pic, you have to know it's the tip of the iceberg. At least you'll know what you have after you're finished. Good luck.
Marv Evans
'69 911E
Old 09-25-2010, 07:19 PM
mcaterino's Avatar
Ah, so familiar, the feeling of being sucked into a Black Hole. The whole first half-year of my project was a series of unfortunate discoveries. But now, two years later, there's definitely light at the end of the tunnel. If you've got the will, the time, and the money, you can deal with whatever you find. Enjoy it, and good luck.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 09-25-2010, 07:56 PM
19 years and 17k posts...
azasadny's Avatar
Glenn,
Good luck! you'll get through this!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-26-2010, 04:50 AM
Tired Member
DaddyGlenn's Avatar
If any one is interested...
I am detailing my adventures in rust repair in a different thread in the Paint and Bodywork Forum.....here
Glenn
Old 09-26-2010, 06:22 AM
Tired Member
DaddyGlenn's Avatar
Shopped around a bit and have ordered a MIG welder. Should be here in a couple days. Waiting for control arms to come back from rebuild service at ER. Gotta source some body parts and buy a couple more small tools.
So today I installed the turbo tie rods. Actually a pretty easy job.
Glenn
Old 09-27-2010, 11:30 AM
scarceller's Avatar
Poke around the front wind-shield as well in the lower corners as this area also tends to rust and then drips water into the cabin behind the dash right where all the electrics are located!
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-27-2010, 12:11 PM
tharbert's Avatar
I'm in the same boat and love it! I bought a Lincoln 140 last year and have been scraping and prepping, replacing bits and pieces. There never is enough time to work on it.
Good luck!
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 09-27-2010, 01:44 PM
Tired Member
DaddyGlenn's Avatar
I think I found the front valance I will use. This is a TRE product and uses the stock bumper.
This one is on a wide body but there is a version to fit my SC as well.
Glenn
Old 09-27-2010, 05:28 PM
ZAMIRZ's Avatar
^Hehe, I took that picture when I used to work for Dave. Yeah, he can set you up with that valence. It's a replica of the NLA Kremer valence from the '80s (also used by Ruf).
Amir
'83 911SC
Old 09-27-2010, 05:48 PM
Tired Member
DaddyGlenn's Avatar
Small world, huh?
I do remember the Kremer Porsches of way back. Not sure about the grill in the middle but I think it will work on a yellow car, good contrast. I'm going to have an IROC whale tail so I'm mixing decades.....
Basically, I need a valance that allows me to keep the stock bumper and fits an SC with stock fenders. This was the only one I found.
Glenn
Old 09-28-2010, 04:15 AM
DaddyGlen-
I feel your pain. My car was about at your point 2 years ago. I bought a MIG welder and jumped in. It was actually fun once the anxiety wore off. Just be slow and careful and measure 8 times before cutting and recognize that the replacement panels almost never fit properly out of the box. The tough part now, once I have the body essentially sorted, is getting those outrageous estimates for painting the car. I have the feeling that painting is not as easily learned as metalwork.
Steve B.
1972 911t
1999 328is
Old 09-28-2010, 04:32 AM
Tired Member
DaddyGlenn's Avatar
Spent about 10 minutes and removed the windshield this morning. Pretty simple job.
I used a plastic thread gauge to push back the trim connectors and then slid the gauge under the trim. Pushing firmly and moving slowly all the way around freed the trim without any damage.
Then using a razor knife with a new blade I cut the seal off the top of the glass.
Then peel the rubber off and the glass is free to be pushed out from inside.
After lifting out the glass and removing the rest of the seal I was greeted with good news. I had a few rust bubbles and expected the worst but it appears that it isn't too bad and I'll be able to get by with some clean up and POR-15.
Glenn
Old 09-28-2010, 07:50 AM
scarceller's Avatar
That's exactly the right way to remove the glass so it does not break. I'm glad you found no major damage in those corners as this would be a tough job to fix.
Sal
1964 356SC (SOLD)
Old 09-28-2010, 07:58 AM
Tired Member
DaddyGlenn's Avatar
Christmas came early. Several items I bought arrived today.
Couple used Corbeau seats. I will recover the blue in a yellow plaid.
A fiberglass IROC style whale tail. Very rough shape so I will be building my bodywork skills even more. (I knew the shape when I bought it and paid accordingly)
And a new Millermatic 140. Let the welding begin!
Glenn
Old 09-29-2010, 05:10 PM
Learning slowly at times
Go Glenn Go! I am sorry to see the rust but know you will do just fine repairing the yellow 911. My hats off to you for tackling the welding repair but know you are the kind of guy to get it done!
Old 09-29-2010, 06:34 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
good luck. i don't have nearly that much rust on my car but its going to be nice seeing how u go about fixing yours. good choice in the miller unit. both my welders are millers never had an issue with either in 10+yrs of use.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 09-29-2010, 07:05 PM
Now in 993 land ...
aigel's Avatar
I would dump that body and get a rust free roller to swap everything over. It will be less time consuming, likely more cost effective and on top of that more durable. That rust you have there will come back out unless you cut it all out to the bone.
George
81 SC (sold)
Old 09-29-2010, 07:49 PM
