rboylan's Avatar
Is this the Turbo Boost Sending Unit ?
Please see the pic. and let me know if I'm correct. Thank you.
1969 911E Albert Blue 1970 911E Iris Blue
1970 911T Signal Orange 1972 911T Gold Metallic
1981 930 Arctic Blue 1981 930 BB Auto(on ship)
1987 930 Cassis Red Met 1996 993TT Black
2007 997TT Cobalt 2017 991 Turbo Cab
Old 01-15-2002, 12:32 PM
Rich
The item you are looking at is the fuel pump boost limit switch. It will shut down the fuel pumps whenever it gets close to one bar. Ground the wire to the manifold if you are running more than .9 bar. Leave the switch disconnected.
The boost sensor is the one that is encapsulated with a red silcone jacket and is about 1 3/4" in diameter. It located more centrally on the same manifold.
Old 01-15-2002, 12:50 PM
