laughac's Avatar
Send a message via AIM to laughac
BAE turbo installed ok, but we routed the PCV wrong
It seems like we have pressurized the crankcase PCV system.
Can anyone help us figure out which hose(s) we connected wrong?
I'll reach in there and try to take some pics in case anyone here has been through this.
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 10-09-2010, 12:01 PM
sjf911's Avatar
Where is your oil-tank vent hose going? You may need an oil catch-can in the crankcase/oil-tank ventilation setup.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-09-2010, 12:14 PM
Turbo outlet paths go where? Obviously the compressor outlet goes to the throttle assy. boot. How about ancillary pressure hoses? Upload a pic of the engine compartment or an illustration of the system.
Sherwood
Old 10-09-2010, 12:15 PM
Connect the crankcase vent hose on the suction side of your turbo and upstream of the throttle .Perhaps directly into the airfilter
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-09-2010, 12:30 PM
Happiest when Tinkering
gsmith660's Avatar
Connect the crankcase vent to oil tank and vent oil tank to catch can and atmosphere vent to turbo suction will suck oil vapor into turbo.
Old 10-09-2010, 01:40 PM
The idea of positive crankcase ventilation IS to draw blowby vapour into the engine to be burned. You may need to restrict the flow and consider a catch can seperator to get just vapour and not any quantity of oil. The vent hose has a restrictor in it already as it is usually connected to manifold vac in a NA application.Venting into the airfilter would be my choice.
1995 993 coupe
2012 Boss 302
Old 10-09-2010, 04:38 PM
what about a getting pvc valve from a 930 ? that should have a check valve to prevent the boost pressure from pressurizing the crank case.
Old 10-09-2010, 06:42 PM
A check valve won,t work because you would then have nil crankcase evacuation when you need it the most. blowby is greatest under boost. The early 930 used a simple vent system similar to what I am suggesting. later 930 added a catch can and drainback hose to assist in oil/vapour seperation.
1995 993 coupe
2012 Boss 302
Old 10-09-2010, 06:59 PM
Stranger on the Internet
patkeefe's Avatar
You need to put some photos up of what you have. Have you done a leakdown test?
Patrick E. Keefe
78 SC
Old 10-10-2010, 04:25 AM
