I would get a new arm, that is a giant stress riser where you don't want it.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
GAFB
I am growing increasingly horrified at the fact that I have cornered in that car at 120 mph.
Gonna buy a lottery ticket today.
Several BMWs |
You are coming right along. I found the rear end way more difficult than the front. You will love the way your car handles after everything is done.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
GAFB
John - what's the plan for torsion bars up front? Also, it looks like you may be due for rear sway bushings. You probably don't want to hear this, but as long as you are that deep into it, you should probably do the trailing arm bushings too.
Several BMWs |
Consider the tube of the control arm carries the same loads as the torsion bar itself. It is actually a hollow torsion bar in series with the torsion bar. Good salvaged arms are not that expensive.
Chuck Moreland - elephantracing.com - vonnen.com |
Stahlwerks.com
Looks like new.....
![]() Just waiting on paint to dry before I install bushings in the morning. ![]()
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Stahlwerks.com
Dave,
These arms came off the gold car I parted a few years back, had in storage. I'll pull the arms off the carrera on sunday and if they look better, I'll rebush them and swap back out. I've got front and rear sway bar bushing and trailing arm bushings on the bench to go in this weekend also. For now, I'll stick with the stock carrera torsion bars, but may eventually go up to turbo size if I start to get frisky with it......
Stahlwerks.com
New bushings are installed, just have to go up on the lift and swap them out.
Stahlwerks.com
Got the old A arms pulled off today, and with Dukes help, got all the ball joints off.
![]() ![]() I'm cleaning up the sway bars too...
Stahlwerks.com
Front arms are back together, and back shocks are in. Just have front shocks to install and swap out the rear sway bar links.
AutoBahned
zehr gut - now hose that other stuff down with Rust Reducer
Stahlwerks.com
I am, piece by piece. She was a northern car for too long before she came south....I'd love to dip the entire chassis in POR
Max Sluiter
That's with an "s"
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Stahlwerks.com
Struts swapped out without issue, other than to find out there was a Bilstein insert on the drivers side, and a no name insert on the passenger side.
She is resting on the ground again. The rear was 1/4" higher (24.75), the front 1" higher (26", but I did reset the torsion bars). I'll let her sit overnight, take her around the block tomorrow, see how she sits then.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" Last edited by jhelgesen; 10-28-2010 at 04:34 AM.. |
Crazy things those previous owners do. I found a set of KYBs in my car with new appearing gland nut and some bizarre packing rope gasket on one side and washer with torx bit for a space on the other side. There oughta be a law with penalties equivalent to driving slow in the left lane of the Autobahn! Nice write up and keep us posted on your progress John.
Stahlwerks.com
I did spray some rust converter around before I put her back down too, pics tonight.
Stahlwerks.com
Drove her around the neighborhood tonight to settle the suspension in. She handled okay, front was a little loose, steering wheel off a little.
Rear end measured 24.75, front was 24.75 drivers side, 25.5 pass side, measured to the fender. Alignment and corner balance is next.
Subscribed
Karaya
'77 Targa 3.0 |
Stahlwerks.com
Suspension upgrade is done, finished the alignment last night. Front sticks like glue now.
