Crankcase oil Temp sensor
I need to replace the crank case oil temp sensor - you know the one with the green/black wire coming from it.
Is it safe to do this without draining the oil? This would make a 10 minute job a 60 minute job. I suspect that a good layer of paper and rags underneath the sensor hole and a quick in/out would not lose too much oil! Any thoughts appreciated.... |
Please be more specific........
Please be more specific in your questions and you'll get a better response. What year and model is your car? Give this information and it will make a lot of sense to readers. A lot of these guys are very good but they are not mind readers!!! Thanks. Tony |
Just changed mine last week, and decided to not drain oil...if it is the one on the passenger side cam chain cover near the top, I got about 3 drops from the hole before I got the other one in. My opinon is that you don't have to drain it...but I am no mechaninc or know it all. 1968 911L
1968 911L #11810584 We first met in '92...now I own you! Last edited by cabriobrad; 10-13-2010 at 02:07 PM.. |
Doh!!
It's a 1981 911SC Regards |
Yes that's the one, cam chain cover just to the right hand side. Will try the quick and dirty method, if anything looks like it's going to pour out I will stuff the old sensor back in!
Regards |
Tags |
911 , oil , sensor , temperature |
