Crankcase oil Temp sensor
I need to replace the crank case oil temp sensor - you know the one with the green/black wire coming from it.
Is it safe to do this without draining the oil? This would make a 10 minute job a 60 minute job. I suspect that a good layer of paper and rags underneath the sensor hole and a quick in/out would not lose too much oil!
Any thoughts appreciated....
Old 10-12-2010, 09:38 AM
Please be more specific........
Jeff,
Please be more specific in your questions and you'll get a better response. What year and model is your car? Give this information and it will make a lot of sense to readers.
A lot of these guys are very good but they are not mind readers!!! Thanks.
Tony
Old 10-12-2010, 09:49 AM
cabriobrad's Avatar
Just changed mine last week, and decided to not drain oil...if it is the one on the passenger side cam chain cover near the top, I got about 3 drops from the hole before I got the other one in. My opinon is that you don't have to drain it...but I am no mechaninc or know it all. 1968 911L
1968 911L #11810584
We first met in '92...now I own you!
Old 10-12-2010, 09:51 AM
Doh!!
It's a 1981 911SC
Regards
Originally Posted by boyt911sc View Post
Jeff,
Tony
Old 10-13-2010, 11:56 AM
Yes that's the one, cam chain cover just to the right hand side. Will try the quick and dirty method, if anything looks like it's going to pour out I will stuff the old sensor back in!
Regards
Old 10-13-2010, 11:57 AM
Tags
911 , oil , sensor , temperature
