Eddyvdw's Avatar
Spark plugs
See picture of plugs 2-6 (can't get 1 out, missing a tool...)
What do you guys think, #4 is not playing along right?
Ed
Old 10-13-2010, 01:13 PM
Senior Advisor
James Brown's Avatar
# 5 is the best one, #4 and 6 if wet could be oil if dry could be running rich. But overall, not bad. How many miles on the plugs? What special tools do you need for #1?
08 Cayenne Turbo
Old 10-13-2010, 02:05 PM
Eddyvdw's Avatar
Thanks.
They are definitely not oily, just a little black.
The tool to remove the plugs is too long and get's stuck between the block and the side.
Ed
Old 10-13-2010, 10:07 PM
m1franck's Avatar
WR5DC plugs, those seem to be a little cold if the car has MFI or carbs. Your picture looks like a long hood 911, so I'm assuming it's not CIS or EFI. Yes, WR6DC is the stock heat range, but I believe the carb experts recommend 1 to 2 steps hotter such as WR7DC to WR8DC. Also, to read plugs correctly you need to do a "clean" chop on the throttle. If you idle around getting it to the garage, then your plug reading is compromised.
Old 10-13-2010, 11:29 PM
Eddyvdw's Avatar
Thanks. I'll change them.
I pulled the plugs after a 30miles drive.
Cheers,
Ed
Old 10-14-2010, 03:42 AM
Eddyvdw's Avatar
Let the car idle for a few minutes (while checking oil) before switching the engine off.
Btw, the car is a 911E (Mfi) from 1972.
Ed
Old 10-14-2010, 03:48 AM
check air flow thru stacks at idle and around 2500/3000 RPM. See if your pulling equal air.
Old 10-14-2010, 04:28 AM
Interesting statement. Can someone elaborate why hotter plugs would be better for such an engine? Our host sells the standard 5 plugs for a T engine. What I know about plugs is that the hotter they are, the less heat they extract from the combustion chamber. So wouldn't hotter plugs affect the valves in a negative manner?
Thx Hessel
'71 911 T
Original Burgundy
Old 10-14-2010, 07:24 AM
Max Sluiter
Flieger's Avatar
You want the coldest plug you can run without fouling.
Old 10-14-2010, 09:06 AM
scarceller's Avatar
Originally Posted by flieger View Post
you want the coldest plug you can run without fouling.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-14-2010, 09:14 AM
scarceller's Avatar
#4 and #6 look like fuel rich. I know MFI runs tad rich but those 2 look a bit to much. I'd run the engine in mid to hi load in the 4000RPM range then shutdown as quick as possible and check them again.
I'm not sure how MFI calculates air/fuel for each cyl but I suspect maybe not enough air or to much fuel in cyl #4 and #6. If this where a EFI car I'd suspect injectors with bad spray pattern and/or to much fuel flow.
Sal
1964 356SC (SOLD)
Old 10-14-2010, 09:18 AM
Eddyvdw's Avatar
Finally pulled #1 as well
You touch on one of the key concerns of a MFI driver; a too rich set up!
The car is a 2.4E MFI with a calibrated pump. The pump nicely heats up via the HE and the thermostat is at full extend when warm.
The oil is not smelly and stays at same level. Only smokes a bit when cold but no smoke when warm. The tail pipe is black / dark grey.
What are the other symptoms of too rich?
Thanks,
Ed
Old 10-15-2010, 09:48 AM
scarceller's Avatar
Few things to watch for:
1 fuel Economy
2 be sure you don't have a cyl mis-fire condition (cyl 4 & 6)
If you have access to a WideBandO2 meter it may help you pin point a rich condition. Like are you rich at idle, PartThrottle and/or WOT?
I'm not a MFI expert maybe others can help figure out what is considered to rich for a MFI car.
What are typical AFRs for these conditions in MFI?
Idle
PartThrottle
WOT
Sal
1964 356SC (SOLD)
Old 10-15-2010, 11:00 AM
Eddyvdw's Avatar
Installed the new hotter plugs and opened the airflow screw on 4 and 6 with half a turn. Drove for about 30 miles quite "spirited". The car feels strong at the entire rpm range and doesn't miss fire.
Let the engine rev at 4000rpm for 20 sec before turning off.
Pulled # 4 and #6 again. Number 4 and 6 plugs are a little less black but still not the desired brown.
Might open the airflow screw another half turn and give it another go.
Ed
Old 10-17-2010, 07:59 AM
Eddyvdw's Avatar
Opened air screw to 2,5 turns on #4.
Changed spark plug gap to 0,7mm
No change
Must be cylinder leakage....
Still car drives really well, strong through the entire rpm range, great sound.
Ed
Old 10-22-2010, 10:22 AM
Friend of Warren
The "E" and "S" engines are really finicky and almost impossible to get the setting right with out a meter to measure exhaust gases while you are making adjustments. I would much rather have the plugs a bit rich, then a bit lean. On my '72 E, the engine was really happy with a hot plug. I ran NGK BPR6ES plugs.
Kurt V
Old 10-22-2010, 10:44 AM
Not to steal the thread, but what about these plugs, 30K miles on them
Old 10-27-2010, 05:04 PM
scarceller's Avatar
The top 3 look good but the bottom 3 seam lean, the one in the center at the bottom looks like it's missing material around the center electrode, if it is it may be indication of mild detonation in that cyl. what engine are these from?
Sal
1964 356SC (SOLD)
Old 10-27-2010, 05:39 PM
Zeke's Avatar
Don't open the air adjustment screw to lean out a cylinder. Those are there to balance out for a smooth idle at 950 RPM. You most likely have a couple of valves that are not seating well. Put new plugs in and run it hard after warming up properly. You can idle some before shutting it down, but keep it at a minimum to get down your street and into your work area. Shut it off without revving the the motor. There will be a minute layer on the plugs from the slower driving but the true color and condition will show through well enough to determine what the analysis is.
You could use a hotter plug in a cold cylinder, but don't take your car to the track or on a long trip in that condition.
Old 10-27-2010, 06:09 PM
They're coming from a 3.3L 78 930 with 100K on it. Those plugs have around 30K miles on. Last track event on those plugs was two weeks ago, pulling pretty good...
Old 10-29-2010, 11:47 AM
