RETIRED
I don't have a Hammer and trying to diagnose....
All of a sudden my 93, 3.6 won't start....I'm thinking it might be the crank position sensor. I don't want to buy a part I don't need.
The engine cranks, does a bit of a stutter when quick start is shot into the intake, I was cleaning the valve covers of seeping oil with spray solvent....might have hit the sensor....otherwise the engine just spins without starting. I USED to have EASY access to a hammer but no more. Any troubleshooting ideas?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
RETIRED
Yep.....fuel pump is running BTW, Sensor has had a bad connection in the engine bay, probably a good idea to replace it anyways....
Formerly reformed
My Porsche laptop is out for an update. If you haven't solved this by Thursday I'll be happy to lend a hand as best as I can.
1968 911P (Paperweight) |
with an ohmmeter at the plug, see if the sensor has an open circuit. no way you're just out of gas, eh? had one last week that the gauge showed 1/4 tank, but it was empty.
RETIRED
Nope, the sensor is good. Checked with an ohmeter and I have fuel......just no spark.
Under the radar
Don't you have OBD? Have you checked for codes?
RETIRED
No OBD, it's a transplant into an 83 SC.
Have you checked to see if the distributor belt is broken? First disconnect the primary ignition source plug (left side of engine compartment there are 2 plugs which supplies 12V voltage to coils for each bank of sparkplugs on the twin distributor). I do not mean the central spark plug leads on the center of each distributorcap. The belt is not broken if the engine starts up.
RETIRED
use a strong magnifying glass and check all the solder joints in the relay and the computer.
Senior Member
Listen to John.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
i have bosch kts 300 hammer tool for sale one owner make me a offer on tool paid $2700.00 when new regards tom
I would try a new DME relay first if the one in the car is old. That's a $40 part that is main suspect in no start situation for the 964s. Have someone help you crank the engine with one spark plug out of the engine touching ground (caution!! do not hold the sparkplug as 45,000V potential in circuitry) to see if there is spark to that cylinder during cranking. If you have fuel and spark the car should fire up.
RETIRED
A DME relay is $23 for the 3.2 style that I have in my Timmins conversion. I just ordered two from our host.
BTW, anyway to test the one I have? It's the POS Hungarian one with the old style round pins.
RETIRED
pop the cover off and check the solder joints.
RETIRED
Nothing obvious....
