pcar9119's Avatar
Computronix DIS6
Has anyone used the compu-tronix DIS6 on their 911. I will be installing mine in a few weeks and was just curious of anyones experience.
If you don't know what it is, it's a self contained coil on plug ignition system. All the needs are incased in the billet distributer, that fires 6 coils. It looks like it will be a sweet set-up. It has 40000 volt coils and an internal timing program, wich should make.installation real easy. I talked to the owner of the company, and he says it's a perfect addition for my carbs. Oh yeah, it's only for carbs.
Old 10-25-2010, 08:26 PM
Very nice looking, simple install and affordable. Is it programmable
80SC (ex California)
Old 10-26-2010, 04:48 AM
I like the concept, but it is not programmable.
From the manufacturer:
"The curve we have is 20 degrees total crankshaft. It begins at 2,000 rpm and is all in by 3,100 rpm. All of the customers report excellent results with this curve. Many say their car has never run as good as it is running with this system.
Lew
Compu-Tronix"
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 10-26-2010, 10:17 AM
gestalt1's Avatar
i like that it allows .045 plug gaps, electromotive systems are more like .03 only. the twin plug option looks like a good deal. does it only work on a 001 bosch distributer?
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 10-26-2010, 06:16 PM
pcar9119's Avatar
DHe told me it would work for my 3.0. I didnt ask about any other applications...
Old 10-26-2010, 07:37 PM
golfbuddah's Avatar
I believe it replaces the dizzy? And coil
Old 10-26-2010, 08:35 PM
pcar9119's Avatar
My compu-tronix DIS-6 is on it's way. I will let you all know how it works..
Old 12-12-2010, 02:36 PM
golfbuddah's Avatar
Any results yet?
Old 12-27-2010, 04:31 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Lew
Compu-Tronix"
20 degrees total advance? And where does it start out? Not sure that is sufficient for our cars (even just a street car), is it?
Gary R.
Old 12-27-2010, 04:35 PM
moneymanager's Avatar
My car wants 34° above 5k or so. This doesn't make sense to me.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 12-27-2010, 04:40 PM
Band.
Well, a SC distributor makes 20 degrees of mechanical advance with no vacuum, so if you can 'start' wherever you want (like at 5BTDC), then it could be ok theoretically. And "pcar 9119" is working with a 3.0.
Probably not so for cars that want 35 or something.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-27-2010, 04:54 PM
Yup. If it was, I'd have fitted one some time ago.
'77 S with '78 930 power and a few other things.
Old 12-27-2010, 05:01 PM
pcar9119's Avatar
I haven't installed it yet. Need to finish the valve job and replacing the head studs...
Old 12-30-2010, 08:22 PM
pcar9119's Avatar
Reading the install instructions, he says to start 10 degrees.
Old 12-30-2010, 08:32 PM
I installed one in my car....1981 3.0 with 46 PMO. Worked fine for about 2,500 miles. The distributor shaft froze in the distributor body.
I have to send it back to Compu-tronix .....I'll let you know what they say
Old 06-14-2011, 02:05 PM
