Idle rough with O2 sensor
I have tried to adjust the idle, 3.2 carrera, and followed all of the info I found here. Jumper BandC, unplug the O2 sensor. Idle can be adjusted, but when I plug the O2 sensor in I get a rough idle and the rpm's drop down some. Bad O2?
Are you sure you're supposed to unplug the O2 sensor when you adjust the idle?
I just jumper the idle air control valve... maybe I've been doing it wrong?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
thought I had read somewhere to unplug O2? I read to check voltage on the O2, but mine has 3 wires and all I have seen on the here is 2 wire sensors. Forgot to mention, I took off the idle control vave and cleaned it. Looked everwhere I know for a loose vacuum hose.
muck-raker
O2 must be disconnected before jumpering B & C on the service plug.
If it's running rough, it's probably not your O2 sensor...could be any of several issues, but usually a vacuum leak. IIRC, you test output where the O2 plugs into the harness which runs to your DME. This is done with a VOM (I don't remember the specs offhand...refer to your Bentley). Don't test the white wires, they are "heater" wires.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Well, you were right, kidrock. Found a dry rotted hose. It is call a sleeve, connects the check valve to the oil tank. This place is a bank of knowledge!
muck-raker
Great news, VMAX1. Me thinks I gotta replace that same sleeve....the tinkering never ends.
Now get out and ***drive***that bad boy.
pelican does not sell the part. Found the part # here and called a Porsche dealer. Less than $6.00. Don't think I ever spent so less to get so much results. Amazing what a little extra air can do. thanks again!
Here,..as in "where"?
Thanks, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
muck-raker
yes, do tell.
Hi
Can some one post a pic of this "Sleeve"? LOL, maybe i need one too.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
You can get the part # by searching parts catalog for a Check Valve Sleeve.
muck-raker
thanks for the actionable intelligence, Vmax.
