-   -   My Triumph Speed Triple project update (http://forums.pelicanparts.com/porsche-911-technical-forum/573869-my-triumph-speed-triple-project-update.html)
al lkosmal 12-26-2011 05:39 PM
juice,
That was always my plan and I had many people request pricing for the kit, but no buyers. It became clear to me that, although priced far below the price you would pay for any alternative, complete ITB arrangement( with ECU)..........what I thought was a fair market price for a complete kit, was too high for the market. The market has spoken. If you PM me your email address, I'd be glad to provide you with pricing......and then you can decide and let me know what you think..
regards,
al
Hebster52 12-30-2011 05:56 AM
Been trying to find out what injectors you used in this application.... Couldn't get my eyes on any info about it..http://forums.pelicanparts.com/suppo...leys/blush.gif
Trying to find out some info about it all over the interweb now too as the TB's I bought. (Same as these) comes without injectors and I would like to know what to look for that would be suitable for the 2,0L engine of mine...;)
al lkosmal 12-30-2011 08:34 AM
MegaSquirt - Electronic Fuel Injection Computer by Bowling and Grippo ÂĐ2010
Hebster....follow the link above to the Megasquirt site. On the left hand side of the page, you will find the link to the MegaManual. Click on the Injectors & Fuel supply section and scroll down to the injector calculator. Lots of good info here.
regards,
al
PS: I used the injectors that came with the Speed Triple ITBs. They were rated at 26 lbs/hr (270 cc/min) at 43.5 psi. I sent these to WitchHunter to have them cleaned and tested. That flow rate will support a 6 cylinder engine at approx. 250 HP .
impmad2000 12-30-2011 09:31 AM
The standard triumph injectors work very well on my 2.2 T.
Hebster52 12-30-2011 12:45 PM
Thanks!:cool:
Appearantly 200cc/min would be enough for my engine when aiming at 150-200hp?
Joeaksa 12-30-2011 01:47 PM
Very interesting thread and great work!
al lkosmal 12-30-2011 05:03 PM
Herbster................you got it...........19 lbs/hr (199.5 cc/min) is a common injector size.
Joeaska....thanks.
regards,
al
Hebster52 01-05-2012 01:20 PM
Here comes a bunch of new questions.... SmileWavy
What thickness are your adapterplates?
Did your respace the TB's so they are the same as the manifold intakeholes?
I guess your Weber manifolds are the same as my Zenith manifolds? If so the TB's need to be moved about 6mm from eachother to line up with the manifold holes.
Did you keep the exit (lower end) of the TB's original oval or did you reshape them to more flow with the round manifold holes? Looks oval in the first page.
I will probably come up with more questions when my project evolves.. ;)
al lkosmal 01-05-2012 03:44 PM
hebster,
1. My adaptor plates are .50' thk (12.7mm).
2. My TB's are spaced to match the weber manifolds spacing. (same as Zeniths)
3. TB's are moved to line up with the manifold spacing
4. My spacers are machined oval on the top, to match the TB's port and 40mm round on the bottom to match the weber port....the transition in the spacer is very smooth and nice.
Note: I thought that the metal around the TB port was not thick enough to be able to open up to 40mm round and still provide enough strength.....I tried it.
regards,
al
Hebster52 01-18-2012 11:34 AM
Trying to figure out how you did the idle control
Did you use the Triumph original idle valve (or-what-ever-it's-called)?
If I figured it out correct the idle control is connected to each TB at the tubes on the inside in your sets?
al lkosmal 01-20-2012 04:43 AM
idle
I did use the Triumph Idle air valve. This valve is controlled by a stepper motor. Megasquirt has the capability of controlling this stepper motor, based on engine temp input. If I remember correctly, their are a few standard choices for Idle air control. I chose the Bosch default and it worked perfectly.
regards,
al
Currently stuck in Las Vegas.....tying to get back to Seattle...the weather is not cooperating.
juicersr 01-20-2012 07:33 AM
Al, email sent. I don't think you got my PM a while ago.
Mawa 02-11-2012 12:25 AM
Great job:eek:
al lkosmal 05-19-2012 01:40 PM
Another Porsche 911 Speed Triple EFI/ITB kit..............1st fire - YouTube
Minor update.....another kit getting installed/tuned....1st fire
regards,
al
911 tweaks 05-19-2012 04:19 PM
nice Al...how does this set up differ form the other set up you created...??
Looks promising... :-)
Bob
al lkosmal 05-19-2012 06:04 PM
Bob
Bob,
Very similar with the exception of the Weber manifold to Speed triple adapter, which I redesigned.......
http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/677379-i-got-distracted-something-shiny.html
.......... and I've opted to use Weber linkage instead of the cable linkage. There are other subtler changes, as well, but I'm just improving it as I go.
I've also built a 3.6 with 46mm TWM T'bodies and next I'm building a hi-butterfly like system using MFI and EFI bits.............I like it.
regards,
al
clutch-monkey 05-19-2012 07:06 PM
will be interested in the 3.6 application soon, i think..
juicersr 06-23-2012 04:23 AM
Al, any dyno run yet showing HP and torque curves?
Also, can u please acknowledge receipt of the customer order on the Renngrill i sent you last week? Haven't heard back from you on any of the emails, pms or voicemails i have sent! Thanks!!
al lkosmal 06-23-2012 03:18 PM
Greetings,
No dyno yet. My buddy Tony (Wolverine) is back on track with his project and mentioned getting a dyno done, so we shall see. Sorry about the delay in responding. I will be away from the office until Wednesday. You have been emailed and pm'd. Keep up the good work, I appreciate it.
regards,
Al
Hoffmanmotors 07-23-2012 06:50 PM
I was Just in Big Lake visiting family, i was literally down the road. I would have loved to see this thing! Awesome job..
-Jeff
al lkosmal 07-23-2012 10:08 PM
Jeff,
Next time you're in the area, you are welcome to stop by and see where all the garage fires start.
regards,
Al
Tiago/Tecnomec 09-23-2012 01:26 PM
Hey all, that is awesome! I have some questions if you donīt mind:
Is there a common plenum for the IAC on the Triumph ITBīs?
Are you driving the car?
Great work, AAA!!!
Best regards
Tiago
al lkosmal 11-22-2012 10:38 PM
turkey day fire up
2 7 racer Colo 014 - YouTube
I had a little time today before the T'day festivities started and got my latest Speed Triple kit fired up. After a bit of fine tuning it's headed to Colorado to it's new home in a 911 track car.
Let us give thanks......................
regards,
Al
timmy2 11-23-2012 12:39 AM
Nice, If you weren't 5 hours north of me I'd be stopping by and oogling.
Too bad I didn't have a 911 when I lived in Blaine 5 yrs ago....
We need to chat about your kit some time. (Or at least I need to ask some questions...) :)
http://www.d-zug.us/itbs.htm
al lkosmal 11-23-2012 09:10 AM
DZ X-Factory ITB Setup
Anytime...stop on by or PM me and I'll answer any questions that you have.
regards,
al
al lkosmal 12-30-2012 10:04 PM
EFI MFI Gasser 001 - YouTube
latest project.
1st fire up!
al lkosmal 01-21-2014 06:57 AM
http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/779992-speed-triple-efi-itb-dyno-results.html
A link to a brief update including some dyno results.
regards,
al
al lkosmal 02-23-2014 05:56 PM
021414 batch 004 - YouTube
........firing up another retro-cool EFI/ITB kit. This is actually the 1st kit I made. i recently refurbed it, new PMO intake manifolds, etc and installed it on my test engine (2.7 w/SC cams) I've fired it up for the 1st time today and, while it does need to be dialed in and the ITBs need balancing....it does fire right up and sounds strong.
regards,
al
Rich Lambert 02-23-2014 06:23 PM
Wow Al, that is bad ass...I like the gray look!
al lkosmal 02-23-2014 06:36 PM
rich....good to hear from you.................I was trying to get the stacks to match my hair.
This might make my 914 a little peppier..............
al
924CarreraGTP 02-24-2014 01:33 AM
My partner has a 1997 Triumph Speed Triple 885cc aluminum frame. It's got a full factory carbon fiber kit, and it is pretty bad a$$. He thinks that it's the $%*t that it spits fire out of the under seat exhaust. I think there's something wrong with it, but he won't listen to me. It's too much motorcycle for the average person though.
JmuRiz 02-24-2014 06:38 AM
Very cool!
regarding your engine, does it have CIS pistons with the SC cams? I've always wondered how this would feel/perform...as my car has CIS on it, but stock '77 S cams.
al lkosmal 02-24-2014 10:22 AM
2.7 w/SC cams
Originally Posted by JmuRiz (Post 7928101)
Very cool!
Greetings,
It does have CIS pistons with SC cams (regrind) I bought this engine, in this configuration, to use as a test mule for my different efi designs...so it has only been on the engine test stand....no seat time, but I've included a link to a thread that covers this configuration.
http://forums.pelicanparts.com/porsche-911-technical-forum/547593-sc-cams-2-7s-observation.html
regards,
al
al lkosmal 09-01-2014 10:45 PM
3.0 EFI/MFI/ITB w/megasquirt
This is my latest EFI project. This was originally an engine in one of my friends early 911s. i knew this to be a good running engine, but, he found that it had two broken head studs and decided to trade up to a 3.2. I decided to buy it and when i dragged it home, I performed a leak-down test The results were as follows:
1 = 2%
6 = 4%
2 = 16%
4 = 12%
5 = 6%
3 = 1%
Hmmmmm.......I tore into the top end, cleaned and visually inspected all parts, measured P&C's, valves, guides, ring clearance, etc. Everything was in spec (low to no wear) and, other than the broken head-studs... in really good shape. I refurbed the top end, de-carboned the pistons and valves/seats, lapped the valves/seats back in, all steel studs, new gaskets, sealed it up and installed my EFI stuff. After wiring and plumbing....it fired right up. I ran it for about 30 minutes to ensure the rings would seat, etc and ran another leak-down test.
The new leak-down test results are as follows:
1 = 1%
6 = 2%
2 = 2%
4 = 2%
5 = 2%
3 = 1%
Those are the leak-down numbers you want...like a new engine.
I spent a few hour today, tuning with Megasquirt.....working on the start & idle.
Here's a link to a video.....of today's work.
Check out the intake....Aluminum turbo spacers, machined for EFI injectors. on top of those are some aluminum spacers that I fitted with vacuum fittings..... on top of those, i'm using MFI t'bodies that I bored out to match the 3.0 large ports, and to top it all off ....some beautiful stax...............listen.....it is close to being done.
regards,
Al
https://www.youtube.com/watch?v=3VeYQv8CvV0
timmy2 09-01-2014 11:12 PM
Need close up pictures of the intake. Too far away to admire in the video. :)
al lkosmal 09-02-2014 06:48 AM
closer
Here you go........pic taken during the assembly.
regards,
al
http://forums.pelicanparts.com/uploa...1409665625.jpg
911 tweaks 09-02-2014 06:58 AM
nice al... any air filtration planned on...? i would hate to see a bug get sucked into one of those stacks and choke up a cylinder... maybe the tea strainers chris neilson used...?
zfbhzfh 09-02-2014 07:24 AM
So, what tub is it going into?http://lifehealthus.com/image/images/28.gifhttp://softwarenice.com/hh.jpg
michelko 11-22-2015 12:06 AM
Hi Al
I have build a similar Setup but have some isues while cranking.
IT takes several revolutions before the engine Starts. In you Videos they Start immidiately.
Can you Provide some Information about your cranking settings?
Thanks in advance.
Michael
jrhb 11-22-2015 11:18 AM
Michelko, is the FP check valve installed and working correctly? Have you verified the fuel regulator pressure?
Originally Posted by michelko (Post 8887179)
Hi Al
Thanks in advance.
Michael
