Auto Heat - Specific Question
Hello, like many others on this board, I am trying to diagnose my lack of heat in my 1984 Targa with Auto Heat.
This weekend, I removed the passenger seat and checked to see that the rod was still attached. It is. Next, I detached the rod in front and made sure that I can mover the lever opening and closing the air flappers. It was OK. Next, I lubed them(rear flappers) to ensure smooth operation. I tried moving the lever that attaches the rod on front, and I was able to move back and forth. And it is apparent that the cables to the rear are working OK.
Next, I tried moving the rod itself, which would not move at all. Is this normal?
I know this subject has been beaten to death, so I will only ask specific questions.
Thanks for reading.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-08-2010, 07:10 AM
pete3799's Avatar
Have you checked all the fuses? I don't have my book handy so i can't say which fuse #'s to check. You won't be able to move the rod connected to the servo motor.
You've discovered that you can leave the rod off and manualy raise the lever so you can get some heat that way. Not sure if the blower motors will turn on with just the lever raised but they might.
Pete
79 911SC RoW
Old 11-08-2010, 08:21 AM
Thanks so much. Looks like my rod is attached and normal. Now onto the "bataan death march" of electrical diagnosis.
Old 11-09-2010, 07:30 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
According to the "Bentley", fuses # 1 and #2 in the engine compartment,
and # 2 and #5 in the luggage compartment are your fuses of interest.
Replace them all.
Also, try to give us more info.
Did your Auto Heat ever work?
Are you getting any heat at all?
Are the footwell blowers working?
You can see the rod activation by removing the E-brake rubber
cover, and using a small penlight.
And as per pete3799, you cannot move the rod.
I doubt that the heater control unit relay,
or the heater control unit has failed.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-09-2010, 09:13 AM
Thanks, Gerry! Prior to last year the heat was awesome! I will definitely check the fuses you mention above. At the moment, I cant hear any fans going, so hopefully this will be fuse related. As soon as I figure it out, I will post the resolution.
Old 11-09-2010, 09:50 AM
Originally Posted by Shadetree930 View Post
I don't recall if the footwell blowers in an 84 had the inline spade-type fuses but you might want to pop off the footwell blower covers to check. The covers are down on the floor right about where your outboard foot would rest when seated. Held in by three screws. If you have inline fuses, you will seem the easily once the covers are removed.
They did not.
I added the fuses to our '86. (10A).
1986 911 Targa.
Only in L.A.:
Old 11-09-2010, 10:09 AM
Also, please check my June 2010 post "Added Fuses and Relays".........
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-09-2010, 10:10 AM
