Senior Advisor
Difference in 3.0 and 3.2 SSI's
Bolt pattern is the same, there is no sleeves on the 3.2's, they both fit, there both thick flange. So what? What makes them different and are they interchangeable?
08 Cayenne Turbo |
My 3.2 SSI'ss have sleeves on them, are thick flange and fit perfectly on my 3.0 L engine.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Senior Advisor
So, why the different part numbers?
08 Cayenne Turbo |
Scott, they fit perfectly because theyre not the right part. The specific for the 3.6 unit is thick flange no recess. The 3.2 should fit only a 3.2 shouldnt be able to fit a 3.0.
Bruce |
Senior Advisor
maddening, just maddening.....
08 Cayenne Turbo |
I thought that as well, and went round and round with this when I bought them. The 80-83 SC head can take those sleeves, and the fit on the 3.2l heads as well. I can't speak for the earlier SC's but this was the case on mine. The part numbers on my SSI's are definitely the 3.2 SSI part numbers, I verified that though SSI in case I had to sell them.
