Speedometer broken, but the odometer still works
Out for a drive today, and I noticed that my speedometer is pretty much stuck between 20 & 40mph. It travels really slowly between those two marks depending on car speed. At a stop light it'll drop to 20mph mark. Both odometers still work. Isn't this supposed to stop working the other way?
Thoughts?
FWIW, the speedometer was working when I left this morning, don't know exactly when it stopped working.....
Old 11-23-2010, 10:43 AM
RETIRED
Joe Bob's Avatar
Best guess, something busted inside....%^b
Pull it, mark the wiring as to what goes where and ship it to either Palo Alto or North Hollywood Speedometer for a rebuild.
If you feel the need, consider a new face on it and the others to modernize the look....
2012 ML350 3.0 Turbo Diesel
Old 11-23-2010, 10:59 AM
If your car is the one shown in the "garage", then you have a mechanical speedo. It could be the internals need cleaning to free up the movement of the needle/coil spring mechanism which responds to the spinning of the magnet attached to the cable from the trans. Whatever it is, it will require opening up the speedo which should be done by a professional shop, IMO.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-23-2010, 11:17 AM
MBruns for President
JeremyD's Avatar
exactly what happened with mine (also a 1974)
Old 11-23-2010, 11:57 AM
Mine did the same thing the other day. So I "flinked" it on the glass(plastic?) and it started working again. But since my odo is broken as well, it will be going off to North Hollywood this winter.
So just try hitting the glass to see if that loosens anything up.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-23-2010, 01:46 PM
Yeah, I tried the flicking of the glass...no luck.
Looks like it's off to sunny CA for my speedo....thanks!
Old 11-23-2010, 04:04 PM
