Tach runs backward
Guys,
I have a weird situation and I need some suggestions or opinions. Yesterday morning when I cranked my car up the tach shot over to the red line and was "operating backward". Just the tach itself not the actual engine operation, that was normal. Red line at idle and as I increased engine speed it would go down in RPMs, essentially running backward. Engine ran and runs fine. it did this for about 2 or 3 minutes then just reversed itself and functioned fine the remaining time while it was in use. The next time I started the car the same thing, then reverses itself after a minute or so and is fine until shutdown, but every time I start it fresh it does this now. Nothing has changed, no work done to the car prior, this just came outta nowhere. What the hell is this all about? I'm guess the tach itself is going bad or a sender somewhere???? Guys give me some knowledge here cause I got nothin!
Dan O
84' 3.2 Targa
Old 11-20-2010, 05:16 PM
topcarbon's Avatar
sounds kind of cool.
Old 11-20-2010, 05:24 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You may want pull the Tach , check the connectors for looseness , maybe crack her open and check the solders for a good contact, use a Big Magnifying glass.
If cracks are found, re-flow them.
Clean all contacts while you are in there. GO to Home Depot and get a wire label pack to keep all wires in order.
I suspect over time our babies solder do weaken and crack causing non-continuity, just had to re-flow my fuel guage.
just my 2 cents.
'85 Carrera Targa
PCA/POC
Old 11-20-2010, 05:28 PM
Innov8's Avatar
Sounds like you have a jumpy tach which seems to be related to the VR or Alt. I am currently working out the same issue and while I am currently sorting an iginition problem... I did some research on this here... try searching "Jumping tach" to see the other threads. You'll read about checking the voltage across the battery while the tach is jumping and you'll probably find that your volts fluctuate with the jumping. Good luck!
04 996 AE (daily driver)
08 A3 Quattro
05 E500 Wagon
PO: 11 Raptor SCREW, 11 GTI 6sp mt, 01 Audi S4 Avanti, 95 Volvo 855 T5R, 82 911SC
Old 11-20-2010, 08:54 PM
Thanks for the input but the tach isn'r jumping it just reverses itself. No other gauges are affected and after a small period of time reverses again to run properly. If it were the alternator it would continue the symptoms sporatically while the alternator was fluctuating so I think I may have a different issue.
Dan O
84' 3.2 Targa
Old 11-21-2010, 04:35 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dan,
If all of the above do not resolve your tach anomaly,
this might be the issue.
Your VR may have an intermittent issue (diodes).
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-21-2010, 07:54 AM
RETIRED
Joe Bob's Avatar
A multimeter will confirm overcharging. Anything over 14v at 2500 rpms is a bad thing.
2012 ML350 3.0 Turbo Diesel
Old 11-21-2010, 08:43 AM
