Dave Hanning
earlyaircooled's Avatar
what struts do I have?
I have a 71E that had the hydropneumatic struts removed and supposedly "s" struts installed. The struts are painted black, not sure if they were originally black or painted? They have aluminum S calipers on them. There is a part number on them 911 341 923 00. Anyone know what I have, Koni, Bilstein, Boge?
1975 Carrera coupe
1974 Targa
1998 Boxster
1999 Boxster
Old 11-18-2010, 09:45 AM
If black...and if you clean off more grunge....you will likely find the "BOGE" brand stamped somewhere on the body. That said...it will tell you nothing as Boge *housings* can be easily retrofitted with Koni of Bilstein, or other brand, *inserts*.
You need to open em up to know for sure.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-18-2010, 09:55 AM
Max Sluiter
Flieger's Avatar
Post a photo. Konis have a necked-down area near the spindle. Boges are straight.
Old 11-18-2010, 11:41 AM
Actually, Boges have a necked down area as well; Bilsteins are straight.
regards,
Phil
Old 11-18-2010, 05:05 PM
All housings "bodies" have some more identifying marks on them...as I've already said. Plus.....you still don't know what's inside...also said. Boges have a "bulge" right over the collar underneath that becomes the stub-axle. Makes "raising spindles" difficult if not impossible..although some have done it. Yes....Boge housings have a "buge"..another clue.
Wil Ferch
Old 11-19-2010, 07:44 AM
myamoto1's Avatar
Follow Wil's advice to determine the type of strut you have. You can also measure the distance between the brake caliper mounting points to see if it's pre '73 (I think that's when it changed). 3" center to center is pre '73, 3.5" is post '73.
If you have the dust covers off, it's pretty easy to tell a Boge vs Bilstein insert.
I can't vouch for the Koni inserts, but the Boge and Bilstein inserts use different retaining nuts. Typically the Bisteins are chrome (silver) and a bit thicker than the Boge's. Also the Boge's have the special hex/oc-taginal cut out in the screw plug and a rubber shock absorber (bump stop) over the insert's shaft.
Josh
85 M491 Coupe - "Fat Bastard"
Old 11-19-2010, 08:33 AM
Dave Hanning
I listed the part number stamped on them in the first post, thought someone could tell me from the part number?
1975 Carrera coupe
1974 Targa
1998 Boxster
1999 Boxster
Old 11-19-2010, 09:15 AM
Part number is only an internal Pordsche part number. In addition....if you look more closely and perhaps wipe away some more grime elsewhere.....you will see the manufacturter's logo or brand name too....like Boge. As said, even if you find this out....the internals could have been changed to anything else...so you still don't know unless you look inside.
Wil Ferch
Old 11-19-2010, 09:18 AM
Good advice here,.....
You really need to take one apart and see what insert you have: Boge or Bilstein. By looking at the numbers on the insert, you'll know if they are stock Boge, Bilstein HD or Bilstein Sport.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-19-2010, 09:27 AM
myamoto1's Avatar
earlyaircooled - just noticed you're local. let me know if you want some help w/ anything. I can't help w/ identifying a lot of parts (variances between years), but thanks to Steve, I'm practically a strut expert. Or at least I can play one on the interweb
Josh
Old 11-19-2010, 09:31 AM
