LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Marlon Targa 86's Avatar
DIY fixing heater blower. Where to start?
Hey guys,
My next project is fixing the heater blower.
Car: 1986 Targa
Problem: when I turn on the heater, no air comes out. My mechanic took a quick look at it a while ago and said the blower/motor is fine. He suspected an electrical/wiring problem
So, what steps do you recommend I go through, trying to track down the problem?
Thanks,
Marlon
Old 11-19-2010, 08:22 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by Marlon Targa 86 View Post
Hey guys,
Car: 1986 Targa
Thanks,
Marlon
Are you referring to the engine compartment blower,
or the footwell blowers?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-19-2010, 08:38 AM
Have you put 12v directly at the fan to make sure the motor isn't frozen? I did that to mine last night and nothing, so I'll be opening it up this weekend and try to fix it without having to buy a new blower ($$$)
Chris
'87 Targa
Old 11-19-2010, 09:01 AM
muck-raker
kidrock's Avatar
If you're not getting any heat at all, I'd check the heater boxes to see if the flappers are operative. I'm assuming that you have the 2 heat levers located at the E-brake?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-19-2010, 09:02 AM
initial's Avatar
The problem must be with the engine compartment blower and NOT the footwell blowers.
I have a Carrera with non-working footwell blowers and there's more than enough heat. A little too much in my opinion.
I can't imagine having working footwell blowers.
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD
Past - 89 911 3.2 silver cab
Old 11-19-2010, 09:52 AM
When I turn the knob on the center console and slide the levers on the dashboard, I get nothing. No air is getting pushed out of the vents and I don't feel any heat.
Old 11-19-2010, 10:39 AM
Hey guys,
Car: 1986 Targa
Thanks,
Marlon
Marlon,
Start simple.
We don't know what your mechanic checked.
But if it is the engine compartment blower,
check fuses #1 (16A) and #2 (25A) by rotating them in
the holders (contact corrosion), and replace as required.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-19-2010, 10:45 AM
Originally Posted by 86 911 Targa View Post
Marlon,
Start simple.
Good luck,
Gerry
Awesome. Will do that during the weekend.
Old 11-19-2010, 11:24 AM
aj88cab's Avatar
Please let us know if you have manual (two red levers at center console, dial numbered 0-3) or auto heat (dial on center console numbered 0-9).
Diagonsis will be different depending on this information
By what you describe above you may not even be turning on the heat if it is manual.
If auto heat you may have a disconnected flapper control servo rod.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 11-19-2010, 02:55 PM
efhughes3's Avatar
It's auto heat. He's got some feedback on RL based on this.
Old 11-19-2010, 04:01 PM
UPDATE:
I now understand the air flow system... I think?! So I'm not getting fresh air flow nor do I get hot air flow. But they originate from 2 different places.
When I turn on the ignition ( not the engine) I do hear a whirring sound coming from the center knob, which gets a little louder as I turn the knob "up".
But when I slide the "handles" on the dash, all the way to the right to 3 (or III), no air is pushed through the vents.
I checked the fuses/relay and they seems fine.
Marlon
Old 11-19-2010, 04:14 PM
UPDATE:
Marlon
Marlon,
Here are the manual and auto heat controls.
If you have the sensor, you have auto heat.
The "whirring" sound you hear is the servo/actuator rod
in the auto heat controler which opens the butterfly valves on
the heat exchanger.
If your butterfly valves are not opening,
I suspect a broken actuator rod connector,
or seized butterfly valves.
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-19-2010, 08:42 PM
Ok, so:
1. butterfly valves don't close when I turn the heat on ( I can hear the servo running in the center console )
2. I don't get any current when I test voltage coming out of the cable plugged in the heater blower
What's next?
Marlon
Old 11-24-2010, 12:37 PM
Scott R's Avatar
There is an arm that goes between the heat lever and the server inside the auto heat housing. On the end of the arm is a plastic socket that fits over a ball (just like the throttle linkage) If someone has pulled hard enough on the manual lever it will snap that ball and socket.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-24-2010, 12:53 PM
I have auto heat.
Old 11-24-2010, 01:41 PM
Scott R's Avatar
I have auto heat.
yes, but do you also have a single lever coming out of the auto-heat unit?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-24-2010, 01:46 PM
I do? I haven't seen it. It's a rotary switch and that's it. Am I missing a part?
Old 11-24-2010, 03:10 PM
Man, I made a typing error:
I DO get current when I test voltage coming out of the cable plugged in the heater blower
Old 11-24-2010, 03:11 PM
Wayah Road Warrior
Shadetree930's Avatar
Ok listen up.
If you have autoheat you must determine if the servo is actually attached to the rod that works the cables that close the dampers.
To do this you will have to remove the passenger seat and then pop the passenger side inspection door.
This is what you will be looking at inside the door.
Try the autoheat control knob to activate the servo.
Does the servo move? Yes? Good.
See the rod? It is still attached at the servo end?
Does the rod move? Yes? Good.
Now does the rod move the cable attachment at the other end?
My guess is that once you open this up and look you will find that one or the other ball clips has failed.
Replacement is a 1 or 2 buck over the counter part from your local Porsche dealer.
Pro-tip .... if you replace either ball, replace em both. Rod measurement should be 118mm center-of-ball to center-of-ball.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 11-24-2010, 03:19 PM
Originally Posted by Shadetree930 View Post
Ok listen up.
The control rod connectors are visible with a penlight by removing the E-brake grommet.
1986 911 Targa.
Only in L.A.:
Old 11-24-2010, 04:33 PM
Tags
blower , heater
